Friction modifier question
Old Jul 24, 2008 | 12:47 PM
Epd444's Avatar
Epd444
I'm changing my rear diff fluid. Is the Limited Slip Axle Concentrate the same stuff as friction modifier? Got a bottle layin around and don't wanna waste a trip into town if this is the right stuff.
Also another quick question. Just use RTV silicone to seal the diff cover correct? Is the red high temp rtv good for this or is there a special one just for the purpose?
Old Jul 24, 2008 | 01:09 PM
ForemanES's Avatar
ForemanES
I used the black ultra stuff without any issues.
Not sure about what you have but I got a tube of limited slip additive from ford. Any more info on what you have?
Old Jul 24, 2008 | 01:18 PM
Epd444's Avatar
Epd444
The bottle says "Limited Slip Axle Concentrate" on the front and on the back description it says can be used as friction modifier.
Whats the best way to add the fluid without makin a mess everywhere?
Old Jul 24, 2008 | 01:22 PM
Neal 97 250's Avatar
Neal 97 250
There is a fill plug on the front of the "chunk" I believe it takes a 1/2" square drive. Possibly 3/8"
Old Jul 24, 2008 | 01:45 PM
Epd444's Avatar
Epd444
Ahhh, I was lookin on the diff cover for fill plug. Bout 4 quarts she holds?
Old Jul 24, 2008 | 05:10 PM
Cuda_jim's Avatar
Cuda_jim
Yep, about 4 quarts. You can fill it through the RABS sensor hole too, on the top of the 'chunk'....just in case you have something in the way of the normal fill plug.
Old Jul 24, 2008 | 05:18 PM
Epd444's Avatar
Epd444
One more question. The bottle of friction modifier doesnt say how much to add. Anyone know?
Old Jul 24, 2008 | 06:11 PM
Cuda_jim's Avatar
Cuda_jim
The whole bottle...even though the 75w140 syn come with it.....That ain't enough, the Posi clutches will chatter later on down the road. You do have posi....right? if not you don't need it at all.
Old Jul 24, 2008 | 07:53 PM
Epd444's Avatar
Epd444
Yup I got posi
Old Jul 24, 2008 | 10:04 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I don't use friction modifier at all. The limited slip works without it and basically turns it into a peg leg with it. I like a little rear end chatter on a sharp turn, lets me know the diff is working.
If you remove the side plug and the diff sensor you can fill through the top hole and when it runs out the side hole it's full. No need to measure the amount that way.
