Sponsored by: Real Truck
E40D transmission
Old Jul 25, 2008 | 11:22 PM
PvtTarget's Avatar
PvtTarget
The gaskets are different to put atop of each other and look through. Some holes line up some don't
Old Jul 25, 2008 | 11:23 PM
jk080's Avatar
jk080
Transmission Rebuilder
Does it move in manual low or with the OD off button pressed?
When you air checked the center support, did the forward clutches apply?
Old Jul 25, 2008 | 11:24 PM
jk080's Avatar
jk080
yes that's fine,
check the gaskets against the plate
Old Jul 25, 2008 | 11:31 PM
PvtTarget's Avatar
PvtTarget
When you air checked the center support, did the forward clutches apply? ( Yes it did) As for being in low overdrive off no go. When I first installed trasmission it when forward and shifted up and down and then stoped. Thats when I noticed the teflon seals on oil pump were damaged
Old Jul 25, 2008 | 11:36 PM
jk080's Avatar
jk080
Is forward now like it is neutral or could it be starting in a higher gear? (like third?)
Old Jul 25, 2008 | 11:39 PM
PvtTarget's Avatar
PvtTarget
Could be if in low and step on it a bit it tries to move but doesn't almost like your trying to push it up a hill by hand. When shifted from park to rev its there and its out as soon as its in neutral
Old Jul 26, 2008 | 07:13 PM
PvtTarget's Avatar
PvtTarget
Forward clutch stack you say beveled washers in first now which way ? So bevel is down right. Cushion plate is which one. Or is that the same as the spacer plates? thanks Robert. p.s took apart and I have got this pack in backwards I think that is why I have to forward. also if this is the fix I am gonna reuse center support bolts anything special I should do to them
Old Jul 27, 2008 | 08:24 PM
jk080's Avatar
jk080
Name:  Fwd Drum Stack.jpg
Clutch stack in the drum; starting with the beveled pressure plate (bevel down - flat side up), then the cushion plate and a steel plate. Then alternate friction steel, friction, steel until all of the plates are in place. Finish with the thick pressure plate.
Old Jul 27, 2008 | 08:31 PM
SpringerPop's Avatar
SpringerPop
JK,
Where are you getting these great photos? Take them yourself?
Pop
Old Jul 27, 2008 | 09:04 PM
jk080's Avatar
jk080
Originally Posted by SpringerPop
JK,
Pop
No, not these, but thanks
I am a member of a few transmissions rebuilders support sites. Me and my father have operated trans shops in Atl for over 20 years. This info for me is a must to be able to run these centers.
Old Jul 27, 2008 | 11:08 PM
PvtTarget's Avatar
PvtTarget
Yes this clutch pack was wrong. The orginal I built was smoked and I now know why the stack upsidedown and missing the cushion plate. I have got the whole thing together now and works great. Only 1 thing, when put in park the pawl clicks a few times till it hooks up how do I fix this. I want to thank you greatly, if you and this site wasn't here I might still be stumped lol
Old Jul 28, 2008 | 08:58 AM
jk080's Avatar
jk080
Good glad to here that its fixed.
As far as the park problem I would check the shift cable, make sure that the cable isn't keeping it from going all the way into park. Mabye disconnect the cable and put into park by hand and check. Dont run over yourself!! Have a friend in the truck!
Old Jul 28, 2008 | 11:13 AM
  #28
krewat's Avatar
krewat
FTE Leadership Emeritus
jk080, I'd rep you again, but can't so soon
RobertJohn
Oct 9, 2014 06:59 PM
robert196614
New Member Introductions
Jan 28, 2014 05:25 PM
mikeb's66
Oct 22, 2013 10:43 PM
Rob Cuenin
Mar 4, 2013 06:11 AM
58AZF100
Feb 17, 2011 10:08 AM
