adding a tach??
Old Jul 23, 2008 | 08:08 PM
6.9 Diesel's Avatar
6.9 Diesel
adding a tach??
i have a 85 f250 c-6trans 6.9 non modified, 2wd, wanted to add a tach to the new cluster of guages ive installed, the only one that ive found, is electronic as far as the hook ups go, i see several (3-4) wires coming out of the assembly housing on the tach, and was wondering how this hooks up and to what, i know its probally unnessarry, but i want to know what kind of rpm i can push and watch on highway speeds, needless to say i want it more than need it, and how can i install it to make it work???
Old Jul 23, 2008 | 10:11 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You will need to find an insturment cluster with a tach in it at a salvage yard.
If you can find one, you just remove the entire cluster and replace it with the one from the salvage yard.
First you need to find out if you have a tach wire and connector near the IP on the engine, this wire should exit out of the alternator harness.
You can see the connector in this picture.
If you have that connector, then all the wiring is already there, you just need the cluster with a tach.
And you will also have to buy a tach sensor at Ford, they cost about 50 dollars.
Standard gasoline motor tachs will not work.
Redline is 3800 RPM
Usually about 3300 RPM is normal for max RPM, and the IP is starting to defuel above that.
Max economy is around 2000 RPM, max torque is slightly under that.
As for cruise RPM, that will depend on what axle ratio you have.
If your max speed is around 85 MPH you probably have a 3.55 axle.
If max speed is around 75 MPH you probably have a 4.10 axle.
Old Jul 26, 2008 | 11:15 PM
83stepside32784's Avatar
83stepside32784
my 89 4x4 5 spd 7.3 was clocked at 103 mph with 411 gears, and man what a speeding ticket
Old Jul 27, 2008 | 12:14 AM
Dave Sponaugle
3500 RPM, I bet your fuel bill was about as high as the ticket.
Old Jul 27, 2008 | 10:27 PM
AndysFords's Avatar
AndysFords
My 88 3 spd w/ GearVendor and 4.11 gears would turn the speedo(which went to 85mph) all the way around to the P for PARK, but I only did it once, I trusted the engine way more than the suspension holding it together.
Old Jul 27, 2008 | 11:26 PM
Dave Sponaugle
Not saying it won't go that fast if the IP is in decent shape, but at those RPM's it sure will be sucking fuel.
A decent IP will usually turn 35 or 36 hundred RPM with the throttle on the floor.
As they get weaker, that number comes down to 31, 32 or 33 hundered.
Old Jul 28, 2008 | 12:21 AM
David85's Avatar
David85
Took mine as far as to jamb the needle against the trip meter reset button (guessing around 100 MPH). Had to try out the new tires after all. Quite erie how smooth the truck was at that speed, turning about 2100-2200 RPM and 850F EGTs if I remember right. Basically just let it gradually gain speed, and gain speed it did.......still lots of room to the floor.
Blurple03
Aug 26, 2016 08:11 PM
72CC428
May 15, 2016 09:37 PM
CheaperJeeper
17
Mar 12, 2014 08:41 PM
03trueblue
Aug 26, 2012 09:30 AM
griiz
Jul 22, 2009 06:10 PM
