Using a Rotunda 78-0100 Tach & Time meter
Anybody got one of these and know how to use it? I just bought one off fleabay for $99, and it looks like it hasn't been used more than a couple of times. Nearly brand new condition. There isn't even any grease in the threads of the GP adapter, and it even came with the "manual" - with NO greasy fingerprints on it!
Unfortunately, though the manual shows how to hook up the meter, and talks about setting the offset before starting the engne and checking the timing, there are a couple of key bits of info missing.
Namely, on a 6.9, how many degrees of offset do you need to dial in? Once that setting is correct and you start the truck, what is the correct timing setting, and at what RPMs should it be measured?
Anybody got those specs?
A "lumy" meter is a whole different animal though. Seems like I've read that you should shoot for some thing more like 5*-10* ATDC because they are triggered by the actual combustion event rather than the pump's fuel pulse.
The Rotunda also has an adjustable offset, so I need 4 bits of info to use it right. Offset, RPMs, and degrees, BTDC or ATDC.
I'm hoping someone around here has experience with one...
Jason
You want right at TDC to 1.5 ATDC with the luminosity probe.
Closer to TDC is better.
1.5 ATDC was rated at 175 HP.
2.5 ATDC was rated at 157 HP.
There was a different IP used in those ratings, one is regular and the second was high altitude.
1 degree ATDC luminosity is about equal to 7 degrees BTDC pulse method.
So Dave, the manual says to adjust the offset on the meter before starting the truck. Got any idea what the offset should be set at in order to properly read/set it at that 1.5* ATDC spec?
Anybody got a copy of the FSM they could scan and email me the pages that give the step by step and specs?
OK, so 20* offset, 1.5* ATDC... @ what RPM?
Dude, this just isn't like you - having to pull one parameter at a time out of you! I'm used to seeing you spill it all at once and very thoroughly share all you know on a given question...
You feeling OK man?
Do you have it in a book or something somewhere? If so, when you get time and get rested up, if you could look it up for me I'd sure appreciate it.
I'm in no hurry. Its running fine right now. I'd just like to see where the timing is at and tweek it if it needs it.
Ok I need to check one of the books I have for specs, I think I still have it.
When you use a luminosity probe, you have to get the cetane value of the fuel as one of the specs used to set the timing.
I think that was one of the reasons IH went to the pulse method, so much simpler than the luminosity method was.
Thanks
Tom D
Tom
