Charging problem
Old Nov 18, 2002 | 04:24 PM
79bigblue's Avatar
79bigblue
Charging problem
At an idle my amps are just above 12, when I turn my lights on, the amps go to about 11 to 10.5. Is this an acceptable amp reading. I thought it should read a little higher than that. Whe I rev the engine up it will go up to about 13. It is a new alternator, new regulator. Any ideas?
79 f250 460 4 speed
Old Nov 18, 2002 | 06:05 PM
Mil1ion's Avatar
Mil1ion
Charging problem
I'm sure those are Volts you are talking about.
12 Volts with engine off is good.
13-14.2 Volts with engine running and no power drain is about right.
There are a few tests involving the revs & Power to accessories that can be done to determine if the Alternator & V/R are working properly.
Dennis
F.T.E. Assistant Administrator
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 18, 2002 | 08:05 PM
Mike W's Avatar
Mike W
Charging problem
You should be getting around 14v at a fast idle. Check the voltage at the field terminal. If it is about 12 volts, the regulator is telling the alternator to put out max voltage. If everything is working normally, the field voltage will be lower with no lights, etc.
Old Nov 18, 2002 | 08:20 PM
androgen's Avatar
androgen
Post Charging problem
79_ford_400_guy
Feb 14, 2013 06:49 PM
mizzitch
Sep 21, 2011 05:16 AM
joners
Nov 22, 2005 08:51 AM
superbepro
Sep 12, 2005 06:10 AM
Fd2504Wheel
Dec 4, 2003 12:51 PM
