01 powerstroke missing at start
Old Jul 23, 2008 | 09:39 AM
vivojr21's Avatar
vivojr21
i replaced all 8 injecters now when i start it, it roumps until the temp gets up
Old Jul 23, 2008 | 11:49 AM
Ponyboychris's Avatar
Ponyboychris
Welcome to FTE.
I'll give you a bump. I'm no expert but there are plenty here to help you out. Could be that you have air still in the fuel lines or air in the oil lines that is causing the romps.
Old Jul 23, 2008 | 12:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE. When did you do the injectors? I think Chris is on this one.
Old Jul 23, 2008 | 04:40 PM
vivojr21's Avatar
vivojr21
i installed them 1 week ago i got about 100 miles on them. the motor also misses on rev up after warm up.
Old Jul 23, 2008 | 04:49 PM
miller_feed
Check the connections on the VC, sometime a wire can get chafed. Did you connect the under VC connections real good. And did you do the quarter mod?
Old Jul 23, 2008 | 05:00 PM
vivojr21's Avatar
vivojr21
what the quater mod? yes i did check the vc connection
Old Jul 24, 2008 | 08:36 AM
vivojr21's Avatar
vivojr21
also forgot to add on rev up it throws blue smoke.
Old Jul 24, 2008 | 08:56 AM
John311t's Avatar
John311t
That would indicate oil, sounds like you have an o-ring problem on one of your new injectors.
Old Jul 25, 2008 | 01:34 PM
vivojr21's Avatar
vivojr21
no more romps. now it studers between idle and 2000 rpms. can some one help with this. thank s million
Old Jul 25, 2008 | 01:49 PM
bushman31's Avatar
bushman31
Maybe far off on this one, but have you gotten the new cam position sensor. Ford just recently, and finally I may add, had a recall on these.
Ron Wilkinson
Old Jul 25, 2008 | 02:20 PM
vivojr21's Avatar
vivojr21
change it allready
Fastbird
Crossovers
Feb 24, 2015 09:51 AM
jimbomac22
Sep 28, 2010 08:38 AM
whadeen
New Member Introductions
Oct 8, 2008 09:22 PM
mikewalsh1
May 10, 2006 05:29 PM
