Aftermarket Products
Sponsored by: Worksport
Scangauge Question
Old Jul 22, 2008 | 03:08 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Scangauge Question
If anyone has a Scangauge on a diesel 6.0 (2005 if it makes a difference), can you tell me if it can display the engine OIL TEMPERTURE? I see that there is a sensor on the engine.
I've got an email into the company, but obviously I'm not important enough for them to answer the question.
Old Jul 22, 2008 | 04:37 PM
ReAX's Avatar
ReAX
If it's internet updateable, you may have to get a software revision. However, the gauge should be able to display anything the PCM knows.
Old Jul 22, 2008 | 07:48 PM
rebelyell618's Avatar
rebelyell618
Alon@ModBargains can probably answer this question for you since he sells the scangauge, just send him a message.
https://www.ford-trucks.com/forums/7...y-pricing.html
he answered a couple questions on his thread back when he was having intoductory pricing (note: sale is over with).
Old Jul 23, 2008 | 01:11 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Thanks, I did just that...I will post their answer.....inquiring minds want to know!
Old Jul 23, 2008 | 01:50 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Well, I did get a quick response: See below!
"I have not used the scangauge on a deisel so I am unsure of the oil temp feature. I looked on the XGauge section on Scangauges website, but was unable to find an answer. (http://scangauge.com/support/pdfs/XGAUGE.pdf) I am sure you will love the scangauge for its other featuers, I especially like mine when towing so I can watch my trans temps."
I too am sure I would love these "other" features, but I was asking about one feature that may or MAY NOT exist. Not buying from them!
Old Jul 23, 2008 | 01:59 PM
Alon@ModBargains's Avatar
Alon@ModBargains
I apologize for not knowing the answer to your question, but I can not make up an answer if I do not know. From the research I have done I dont believe you can check the oil temp, but there may be something new since they have updated their site.
If there is anythign else I can help you with please let me know.
Old Jul 23, 2008 | 02:59 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Just thought you had more swing with the manufacturer than I did!!! Obviously, they don't comunicate very well......with anyone.....customers nor dealers.
Old Aug 1, 2008 | 01:22 AM
bczolone's Avatar
bczolone
On my 2004 I have a Scan gauge II but it dosen't read oil temp or trans temp...I was told from the guy whom I ordered it (who is the supposed programmer) that they would trade mine out for one that was able to read more parameters when that became available...that was 2 years ago...plus mine sometimes has a mind of its own and does weird stuff...they are OK and read some codes but not all codes or parameters...and as you have found out their customer service is all lip service.
Old Aug 1, 2008 | 05:32 AM
FTE Ken's Avatar
FTE Ken
These questions are answered on their web site. Click the gauges link and it shows the 12 standard OBDII gauges it supports (oil temp is not one of them). Click the XGauge page and it tells you if the vehicle has a sensor they XGauge can display it. The XGauge feature to setup for custom, manufacturer specific gauges (ie, non-OBDII gauges). Right there in the manual and on their site. They even document how to do it for Ford on their site. The device supports standard/generic OBDII parameters but you can't expect it to read and label the thousands of different manufacturer specific parameters out of the box, which is why it gives you XGauge to program in the manufacturer numbers and label them. They can't tell you if it supports a specific gauge on a specific vehicle because there are hundreds of different models of vehicles each with its own set of sensors it does or does not have and they'd need to access each vehicle model to know.
Best bet is to obtain a list of manufacturer specific parameters and then read the XGauge section of the manual to program it. If the computer has a sensor for it it can display it, just a matter of setting it up.
All in jest dude, but it seemed you couldn't see the forest through the trees.
