filter for 6spd.?
Old Jul 22, 2008 | 03:55 PM
03_PSD's Avatar
03_PSD
subscribing.
The links no worky?
Old Jul 22, 2008 | 03:57 PM
pullinair's Avatar
pullinair
Links worked for Miller 2 or 3 month ago when he did his rebuild. I dunno, maybe ZF shut the web site down. It sure was handy. I will do some new digging.
Old Jul 22, 2008 | 06:15 PM
pullinair's Avatar
pullinair
I tried accessing the links from other sites and links still do not work. I did not save on a hard disc. Lesson learned.
Old Jul 22, 2008 | 06:50 PM
F350-6's Avatar
F350-6
Don't worry Tim. I once bookmarked some links some smart guy posted and they look a lot like the ones your trying to post. I just checked and those links are working.
Here's a link to the other thread. Somebody ought to rep that guy.
https://www.ford-trucks.com/forums/7...ml#post6148715
By the way. I would have sworn you were wrong about the location of the cooler. I just went and crawled under my truck to trace the lines (jumped and hit my head when a drop of cold water from the AC landed on my chest) and discovered the cooler I remember is not there. The lines go into the radiator.
Thanks for the info.
Old Jul 22, 2008 | 11:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
http://www.dieselsite.com/index.asp?...ROD&ProdID=761
Old Jul 23, 2008 | 12:09 AM
Miller's Avatar
Miller
the zf has a pump, it works like any oil pump, and its driven off the front of the counter shaft. with 3/8" lines going to the cooler.
Old Jul 23, 2008 | 02:01 AM
Miller's Avatar
Miller
i looked at what is on dieselsite, i dont know it the little pump would like pushing the oil through that kind of filter. its a small pump and with too much back pressure a check valve opens and the oil never leaves the trans.
even though a manual does not get as hot as an auto, i still think that a filter is a good idea, with the syncs wearing out with every shift, and the gears and bearings shedding metal, the pump has a screen over the pickup and there is a magnet in the bottom of the case so its obvious that ZF thinks that debris will gather in the transmission.
Old Jul 23, 2008 | 08:31 AM
pullinair's Avatar
pullinair
Miller, This magnefine should do the job. Same thing as the OEM one. but for 20 dollars. Magnefine--Your Source For Magnefine Inline Filters.
or (non magnetic) http://www.dieselfiltersonline.com/F...er-Ft-166.aspx
or (magnetic) http://www.dieselfiltersonline.com/F...er-Ft-167.aspx
Here is one discussion on it. Second to last post sums it up. TheDieselStop.Com Forums: Magnetic Inline Transmission Filter Element Replacement?
All would be good choices in my opinion.
