Flickering headlights..... knob removal??
Old Jul 21, 2008 | 08:38 PM
kc 300EX's Avatar
kc 300EX
Flickering headlights..... **** removal??
Ok, so I have a 1976 F-250 Highboy with a 360, 4 spd manual....
For some reason, my headlights only work when they feel like it... I pull the **** and they come on. Within a few minutes they shut off, only to come back on again, and go off again, and come on again, at completely random times. Both headlights go off and come on at the same, all the other lights (tail lights, parking lamps) stay on.
Ive traced all the connections under the hood, and replaced the high/low beam switch on the floor... which was pretty corroded.
I want to check the switch behind the dash... but... I can't remove the light switch knod or the windshield wiper knobb! I didn't try TOO hard... because Im scared of breaking it.... I don't know whether to pull or twist or what but I cant get them out.....
Anyways.. Anyone have any other idea what it could be?? I'd like to drive at night some time soon....
Thanks guys!!
Old Jul 21, 2008 | 09:16 PM
Tedybear's Avatar
Tedybear
Best done with the battery disconnected.
There probably will be a small "pin" on the switch itself that has a small spring under it. All you should have to do is pull the headlights to the 'on' position and press the pin inwards against the switch itself. The shaft should pull straight out. Check out photos of the replacement switch, or if you've already purchased it? You should be able to see what I'm talking about.
S-
Old Jul 21, 2008 | 09:37 PM
ranger429's Avatar
ranger429
On the top side of the switch as it is mounted in the dash there is the pin that tedy speaks of. Reach up under the dash and push the pin in and at the same time pull the shaft and **** off as one piece. Make sure the headlights are on before pushing the pin. You can after getting the **** and shaft out push it back in gently to turn off the lights and then it will slide right back out. If you push it to hard it will lock back in and you need to repeat above steps again.
The W/W **** just pulls straight off. If you look on the backside of the **** you will see a small indent where you can pull the spring steel clip back and relieve the pressure from the shaft.
If none of this makes sense to you try a search of the forum, it has been beat to death plenty times before.
Old Jul 21, 2008 | 09:38 PM
F250army45d's Avatar
F250army45d
then **** should pull right off some have a really small set screw on them. replacement ***** are like 8 or 11 dollars. then after the ***** off you unscrew the nut and switch slides out under the dash.
Old Jul 21, 2008 | 09:46 PM
webster52's Avatar
webster52
I have a 76 f250 4x4 highboy that does the exact same thing. I thought maybe he was winking at cute cars when the went by
Old Jul 21, 2008 | 10:18 PM
kc 300EX's Avatar
kc 300EX
Thanks guys... I had a feeling it would be pretty easy as long as you knew what to do.... I'll see if I can get it out tomorrow and fix whatever the problem is.
Old Jul 21, 2008 | 10:22 PM
ranger429's Avatar
ranger429
None of the original ***** on 73-79's have a set screw.
Old Jul 22, 2008 | 01:16 AM
F250army45d
mine may not be original mine in my truck and my spare switch both have the same pull ***** with a set screw.
Old Jul 22, 2008 | 03:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/79: Wiper Switch **** / Headlamp Switch **** & Shaft
Does the **** match the others? The headlamp switch **** only came with the shaft.
Wiper **** / Retained by a spring clip which was only sold with the ****.
1973/74: D1AZ-17513-B / Also used on 1971/72 LTD's.
1975/79: D3OZ-17513-B (was-A) / Also fits: '73/76 Torino/Montego; '74/76 T-Bird; '74/80 Pinto/Bobcat; '78/79 Bronco.
D3OZ17513B is still available from Ford / MSRP: $12.28 / FTEpartsguy.com price: $8.84
1973/75: D3TZ-11661-A
1976/79: D4FZ-11661-A / Also fits '73/80 Pinto/Bobcat; '78/79 Bronco.
Old Jul 22, 2008 | 07:46 AM
1pump's Avatar
1pump
The problem is the original Ford wiring, which doesn't use headlight relays like the rest of the world. There's a circuit breaker built into the switch which carries the current for ALL the lighting in the truck. The breaker gets weak with age, hence the pulsing or flickering lights. My '76 does the same thing, but I haven't got around to fixing it yet (it's somewhere around #15 on a list of about 120 things to fix).
Somebody posted a link or a tech article here a while back on how to rewire the headlights using relays like "normal" vehicles do. Not a bad idea.
Old Jul 23, 2008 | 10:32 AM
jdlongmate's Avatar
jdlongmate
I just fixed this same problem on my truck. My headlights were flickering like that so I started by replacing the dimmer switch on the floor, then the dimmer switch pigtail...
That didn't work so I replaced the headlight switch and it fixed the problem. I stopped by the junkyard and pulled a headlight switch out of one of the old trucks.
First, pull the ***** for the headlights and wipers straight out...They will just pop off.
Then you got to take the dash panel off (the black plastic piece that covers the display cluster). Its just a couple of screws.
Then you will see a thin locking nut that holds the headlight switch onto the front of the dash. It is groved and I used a flathead to get it moving. Once this is off, you can pull the entire switch out the back of the dash panel.
Once it is free, you can remove the actual switch component from the plug by just pulling it away from the plug. Pop in a new switch and your good to go...
w5nra
May 19, 2020 06:16 PM
rustypierce
Oct 27, 2016 02:24 PM
Bob_91SC4x4
Oct 11, 2015 10:28 PM
atomicjoe23
28
Jul 12, 2015 06:52 PM
cowgirlmechanic
Aerostar
Jun 9, 2009 09:40 PM
