conveting old linkage to cable system
I am wanting to convert my gas pedal to a cable system for a 1bbl carb. Its a 56 ford f100 223 L6. Im sure quite a bit of people here have done it in there trucks, and im wanting to know how they did it. Does anyone know if they sell kits for doing this, ive been looking but havent found anything, or will i have to be making my own brackets? Pics would help me out if anyone has any of there cable systems or just some good ol pointer would do.
Throttle linkage
I'm in the process of connecting my pedal to the throttle; '90 EFI 302. I'm using stock style pedal connected to the bracket and cable from the Crown Vic donor. I had the hanging pedal from an Explorer but didn't care for the look. Lokar makes all linkage cables, but I've heard their a bit pricey. You should be able to get something from 70's or 80's carb setup.
Tom
Tom
Theres a place making clones now of the high dollar Lokar setups, its called Spectre.
IM waiting on one to arrive for my 302/c4
I wanted to use the old pedal and rod setup but after scratching y head and holding three gas pedals and about four different linkage setups on the firewall and under the dash I cant come up with a way to do it so I found Spectre.
I searched and came up with this company SFX Performance Parts and Auto Accessories - Est 1997
They had the best prices, they even beat Jeggs.
First you have to determine which direction the throttle arm on the carb must move, does the linkage need to pull or push? A cable works best in tension (pulling) so if yours needs a push you'll need a bellcrank and a solid rod at the carb to push the arm. Next you need to determine how far the linkage must move to go from idle to full throttle (the throw). Are you wanting to use the stock gas pedal? I'd guess no if you want to change the linkage. Next you will need to buy/make/modify a pedal to produce the right amount of throw in the right direction at the pedal. A quick trip thru your local salvage yard should produce a pedal you like that can be used or modified, and a lot of late model cars use cable throttle linkage you could modify as well. Grab any pulleys, bellcranks and attachment hardware off your donor as well. From there it's a pretty simple job to rig it all up.
Then you would need to change the throttle arm shape so it would operate by pulling, rig a bellcrank to change the direction, or make a bracket that would point the cable in the right direction at the carb. If it can be moved with solid linkage it can be moved with a cable, it just might be easier to use solid linkage tho. If I knew more about what you are trying to accomplish by using a cable I could provide more specifics on how it might be done.
well the only problem im having with the original linkage is getting it to fit right. it is a ball that goes on the throttle arm and then to a small bracket that has a ball keeper on it. and then that attaches to a peice bolted to the manifold that rock backwards when u hit the accelorator. it would be easier to keep what i got but i cant get it to work right. push the throttle too far and the keeper pops off the ball.
I have a edelbrock 600 cfm carb on my 351w installed in my 56 f100 and a stock (repop from mid fifty) accelerator pedal and linkage ( had to rework part of the linkage to make it align with carb). I replaced the solid rod (from carb to pedal linkage) with a cable from lokar ( it's your toy so it costs a little more to go first class) it works great. I have had this arrangement for about 6 yrs with no problems.
Chuck
Chuck
51merc
09-25-2016 01:23 PM
michaelshewkin
01-21-2014 06:51 PM
S.P.
20
01-10-2009 12:01 AM
Jharger
16
12-27-2005 10:56 PM
