I have a 2003 F250, every now and then the steering goes erratic. It will pull left, then pull right, and it is hard to control. Fluid is good and there is nothing I can see that is loose? Ball joints were recently repalced as were lower control arms. Any help is much appreciated, it is real scarry when this happens at 50+MPH.
Do you have a 2 or a 4 wheel drive? Does the wheel ocillate left and right or does it just jerk in either direction at any given time? If it ocillates, do a search for death wobble on this site. That will help a lot. If it just jerks, I would check the wheel hub/bearing assy real closely (4wd model only, I think?). More experience should jump in here soon.
Best of luck, Aaron
Iy just pulls in one direction then the next. This is a 4wd. It is at local ofrd dealr now and he claims it is the steering assist and the power steering seals are bad. There is a small leak in the outlet hose on the PS pump.
when turning the steering wheel will not correct sometimes, and when taking corners and curves in the road, i will turn the wheel a little the all of the sudden it pulls to the hard to that side.
Would that mean its the power steering pump?
Also since i bought my truck it has had a bad shake on the freeway at 75+
Replacing the internal seals in the spool valve involves tools that look like inside-out piston ring compressors - the seals are plastic rings that fit into grooves in the spool valve. You need to expand them, slip them onto the spool valve, and place into the grooves.
I did it once to a mid-80's e-series steering box, but only to replace the springs - not the seals. It was so loose it was horrendous. But the seals weren't leaking.
If the box decides to just take off in a direction of it's own, the spool valve is allowing fluid to flow in a certain direction (leaking past the internal seals).
And this is all assuming the bore where the spool valve goes (and the valve itself) is not worn out and all scored or grooved.
Actually, looking at a service manual just now, it doesn't look that bad to do - maybe check with Ford to see what parts they actually have - but I don't think they supply parts - just complete rebuilt boxes.
The valve is called a "rotary valve" - I called it a spool valve for some reason all these years
Here's a link I found, for a Saginaw box, the Superduty one is similar, but ...
