460 EFI MAF conversion
Old Feb 26, 2010 | 07:18 AM
  #61
larrylass's Avatar
larrylass
Originally Posted by 460Kirk
Perhaps you could cut and paste it in here?
Fordmuscle might have a problem with that,Sorry, BTW its only $15.00 for a subscription
BigLar
Old Mar 9, 2010 | 07:36 PM
  #62
mattsuperduty's Avatar
mattsuperduty
Originally Posted by solidrunner
I have a MAF 460 in my '78 F250. The 460 dist. has the mounting boss and holes for the TFI module. You have to make a hole in the dist. to allow the TFI module to plug into the trigger under the cap. I used mustang parts for this, everything bolted in. I can take a picture of my set up if anybody wants it. I used a painless harness and an A9P mustang computer. I replaced all the sensors on the motor with ones for a mustang. You kind of need to make the TPS fit, but everything else bolts right on.
I have 36lb injectors on mine with a 75mm PRO-M MAF. I have heavily ported E7 heads, with a custom ground comp cam, roller rockers, 10.5:1 compression and the whole thing is balanced.
If you run a MAF, you will need the y piece from the intake of a MAF F-150 or Bronco, I got mine from a pull a part for a buck. If anyone has questions on this conversion let me know. I spent a bunch of time figuring out a lot of this crap, I would like to save people the time.
I have an 89 f250 460 efi (speed density) a/T (C-6) 4.10 trac-loc rear . I would like to convert to mass air . I would like a quicker throttle response , a little more torque off the light towing a trailer, and would tire-spin with no load be asking too much? My budget is $600 or less. Any junk yard parts list or combo of new parts and sizes would help. I have light blue topped injectors; would an 80 mm pro-m meter ,proper intake piping and specific ???? computer and lay-over harness get this done? Timing chain and gear set ( part numbers or specific HO application ) are they of any help ?
Old Mar 12, 2010 | 08:18 PM
  #63
mjp_t98's Avatar
mjp_t98
I'm really not sure it's worth the bother to go with a MAF for a stock motor. For a modified one, there seems to be expertise (or claimed expertise) in doing MAF conversions than modifying the SD tables.
Maybe just an upgrade to the latest 460 SD system would suit you best. Apparently they give slightly better idle control. I can't imagine how a MAF system could improve the throttle response I get on my stock 94 SD system.
You may get better economy though, because many of these 460 SD systems are locked out of closed loop control. The systems used as a basis for MAF systems usually allow closed loop.
What's wrong with the SD system you have?
If you insist on doing it, you'll need to get a tuner to modify a MAF system for you, as I don't believe there were any OBD-1 MAF systems for the 460. The CA/MA 460 trucks of 96 and 97 did use a MAF, but they are OBD-2, and while a conversion is possible, it's probably not worth it. They used a 80mm MAF on the 460.
Old Mar 19, 2010 | 02:31 PM
  #64
Shawn63200's Avatar
Shawn63200
Originally Posted by 1994460NC
The overlay kit I have has the wires nesessary for an EEC-4 mass air conversion. Is it worth the trouble to go ahead and upgrade to the 5? If I'm goin' in, I might as well make it worth while! It seems the 4 will be an easier install. What are the benefits of installing the 5 vs the 4?
Thanks guys
Anyone? I have the full harness from a 2000 Mustang GT, which has the plug to use a Lightning MAF meter directly. Is it worth putting all the extra sensors of the EEC-V on though?
Currently looking at going with the OBD1/EEC-IV from a 5.0 auto truck and getting a quarterhorse tuner from Moates and/or a Baumann for the trans.
Old Jul 4, 2010 | 09:15 AM
  #65
1994460NC's Avatar
1994460NC
Would the quaterhorse used in conjunction with my stock ECU allow me to convert from speed density to mass air? I have a '94 with a 7.5L and an E4OD. I have everything else in place (plumbing, wiring, etc). I just need to know which way to go on the computer. I'm ignorant when it comes to ECU's but this is what I've concluded so far (correct me if I'm wrong). The ECU has all the "stuff" in it that controls all the various electronic controls on the vehicle. Mine in particular contains the stuff to control a speed density 7.5L with an E4OD. I have noticed that alot of people go with a Mustang ECU (for the fuel injected mass air stuff) and then pair it with a stand alone trans controller (for the E4OD stuff). Since my factory ECU already has the E4OD stuff, can it be upgraded to drive a fuel injected mass air system (ie the quaterhorse)?
Old Jan 24, 2016 | 09:42 PM
  #66
Steven Yates's Avatar
Steven Yates
experience please
what is your take on changing pistons from 8.5 stock to 10.4 dove c bored 30 ovet, porting the heads, adding a medium aggressive tow haul cam, and using the rest of a stock setup from an 89 efi 460?
Originally Posted by Conanski
OK.. let me see if I can offer some input and clarify some things. On paper sefi mass air has the potential to deliver better milage because it fires the injectors sequentially instead of in batches of 4, and performance because it actually measures the amount of air the engine is using and doesn't totally depend on manifold vacuum and preset tables like SD does. The reason it's not a foregone conclusion that you'll get better milage with mass air is because a lot depends upon how well the system is matched to the engine, and it won't really be matched that well unless it's an all stock motor, the computer and MAF meter are a matched pair, and both of these are matched to the engine. It's a common misconception that MAF meters are matched to the injectors, but really the MAF meter is matched to the computer because it holds the meter's transfer function which is the voltage generated versus the amount of air passing through it. Any other claim of "calibration" by MAF manufacturers is really just a trick to make a larger MAF/injector pair appear to operate like the stock parts. And this technique works up to a point but the further away you get from what the computer is programmed for the worse the results. So an 80mm meter and 24lb injector pair would work reasonably well on a computer setup for a 70mm/19lb pair, but a 110mm/48lb pair would run terribly without tuning. And that leads to the last point I wanted to make, a 302 computer could be used to run a 460 but it wouldn't work that great without tuning.. no matter what injector and maf meter were used.
Old Jan 25, 2016 | 06:22 AM
  #67
BuickBrian's Avatar
BuickBrian
The higher compression pistons will fit and give more power, but you will constantly be fighting spark knock with todays fuels (93 octane at best). You will have to retard the timing to keep it from pinging, and then you are back down to the power level you had with the stock compression pistons.
Old Jan 25, 2016 | 06:40 AM
  #68
BuickBrian's Avatar
BuickBrian
I started this thread back in 2010, so figured I should follow up now that someone resurrected it. I attached a picture of the setup I put in my 89F350.
The hoses from the Throttle body are stock 460. The y-pipe is from a MAF 96 F150 with a 5.0l engine, the flex hose from the Y to the MAF is the intake hose from and Ingersol Rand P185 portable air compressor, and the MAF meter is a C&L 80mm unit. The air box top is from lightning F150 pickup (this part is kinda hard to find since Ford quit making it--not a lot of lightning pickups in the junkyard!). ECU is a C3W1 93 mustang 5.0 MAF unit.
I have since changed the MAF meter down to a 76mm C&L unit and it works much better. The inlet size of it matched up better with the lightning air box. Since this is a towing truck and I spend 99% of my time at 3000 rpm or less, the 76 is perfect. I also changed the flex hose out and put in two smooth elbows I found that. Changing to the smaller MAF sensor and smooth hoses got rid of a stumble I had during transition back onto the throttle after descending a hill and starting up the other side. This also allowed me to get rid of the "air adjuster" box you see mounted in front of the air cleaner in the pictures and plug the MAF straight into the computer. This is a device you can buy to adjust the output signal from the MAF meter either rich or lean.
Running 30 lb injectors with the matching 30lb sample tube in the C&L MAF meter.
Engine has ported E7 heads with Manley SS Cobra Jet size valves installed in it. Rocker pad machined to accept comp cams steel roller rockers on 7/16" screw in studs. Has a Comp Cams roller cam I had them custom grind for my towing application. Exhaust is a set of the Hooker headers made to fit the 460EFI trucks, but I custom made the pipes from the headers to the CAT inlet using mandrel bent elbows. I wanted to get the exhaust overtop of the trans crossmember instead of under it like the factory did.
Old Jan 25, 2016 | 06:42 AM
  #69
BuickBrian's Avatar
BuickBrian
Here is a pic of the truck this is all in.
Old Jan 25, 2016 | 02:59 PM
  #70
Steven Yates
that is a beautiful truck!!
my original plan is to go with the western motorsports SDS programmer which is a plug and play replacement for the factory computer. with it i can change timing and fuel curve...
about how much do you think the conversion to MAF cost you?
Old Jan 25, 2016 | 07:48 PM
  #71
cbakker's Avatar
cbakker
You will not get to 10.4:1, because of the taller deck height of the later blocks. The E7TE heads are fairly restrictive, and porting them does help. Doing a MAF swap is not a simple bolt on process as many(including myself) have found out. There are multiple ways to go about this swap, but you will most likely spend a lot of money on at least part of it. If you go cheap, you will pay for it in poor drivability. I have a habit of trying to go about things the best, and most logical from a ford factory standpoint. I have recently realized this is probably the most expensive.
Sent from my iPad using IB AutoGroup
Old Jan 26, 2016 | 06:42 AM
  #72
BuickBrian's Avatar
BuickBrian
I started with a kit I bought from the people at mass-air.com (website is still there, but not sure they are still in business). Don't remember how much it was, but it wasn't cheap. I the end, the only thing from that kit I am still using is the harness, although I had to change the length of pretty much every wire on it to make it look clean--they made all the wires extra long to make it universal. Now that I have the wiring diagram and know what to do, I could do it a lot cheaper making my own harness and buying the MAF meter, and doing the plumbing on my own. Getting ready to do just that to a 90 EB Bronco I am putting an EFI 460 and ZF 5-speed in out of an 89 F250.
Old Jan 26, 2016 | 09:06 AM
  #73
cbakker's Avatar
cbakker
I went with the Fiveology kit, because at the time it was the only place I could find a MAF EEC-IV. I'm in the same boat, because after doing it, and knowing what I know now, I would have scrapped it all together from a junkyard. This wouldn't be as easy, but it would have been cheaper in the long run. Did the Interactive systems tech kit come with an EEC-IV?
Old Jan 26, 2016 | 09:43 AM
  #74
BuickBrian's Avatar
BuickBrian
Good point--yes, the kit from Interactive systems came with the C3W1 controller from a 93 Mustang. Forgot that I am still using that as well! You can get Mustang MAF controllers off Ebay and from others that deal in Fox body GT mustang parts. The A9L code is the one that most people like to use. Mine was much easier than what you are doing though since I have the 5-speed manual transmission. The E4OD adds another layer of complexity to the controller setup and wiring.
Old Jan 26, 2016 | 12:13 PM
  #75
cbakker's Avatar
cbakker
For any MAF swap on a truck with an E4OD the only way to use one PCM without added controllers is to find one from a MAF F-150, or Bronco. I didn't want to have anything besides a ford program running my trans, so I paid good money for a WAY1 EEC with my conversion kit. A9L's are a dime a dozen, but for the one I needed, they are hard to come by.
