eec relay
Old Nov 22, 2002 | 09:32 AM
troposcatter's Avatar
troposcatter
eec relay
[updated:LAST EDITED ON 22-Nov-02 AT 10:34 AM (EST)] Before I test my contortionist abilities just where is the EEC relay? I have an 84 F-150 4x4.
Old Nov 23, 2002 | 01:14 AM
steve83's Avatar
steve83
eec relay
Probably mounted to the driver's fender near the hood hinge. Use the wire colors from a wiring diagram to ID which relay does what.
Old Dec 3, 2002 | 12:40 AM
krazdndenver's Avatar
krazdndenver
eec relay
The EEC IV relay is most likely on the fender near the battery. Most likely the fuel pump relay is next to it. Both relays have power from a fusable link of the starter relay. The EEC IV realy is a brown connector, the fuel pump is green. Why do you need to know this any way, what is the problem?
Robert
72 F100 Ranger XLT W 86 5.0L EFI W/ AOD
krazdndenver(No Email Addresses In Posts!)
www.geocities.com/krazdndenver
Old Dec 3, 2002 | 09:59 AM
brown 4x4's Avatar
brown 4x4
eec relay
Well ya got 3 different places now :-) . Mine is mounted next to the computer on the right side. The computer is under the dash just right of the steering column. There should be a wiring harness going through the firewall leading to it.
1995 F-150 Supercab XLT 155" 4x4 M5OD 302
1986 F-150 4x4 NP435 300
Old Dec 11, 2002 | 07:53 AM
steve83's Avatar
steve83
eec relay
Old Dec 11, 2002 | 10:55 AM
troposcatter
eec relay
I really don't have to find it but I'm going to install a couple of auxilliary power relays for other stuff such as radiator fans and stuff and I just like to isolate stuff like this from the regular harness to ovoid overloading problems and such, I also thought about scrounging up a second EEC relay and socket for the secondary circuit.
Old Dec 11, 2002 | 10:34 PM
steve83's Avatar
steve83
eec relay
Don't use the '84-style relays - they suck and are hard to find. Use the '92-up Bosch-style 30A standard relays used in Volvo, Porsche, Jaguar, Ford, Lincoln, Mercury, Mazda, etc. Even WM sells them from Blazer. You can get socket for them online for under $2.
http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=3
djs556
Jul 31, 2020 05:54 PM
ratsram
1983 - 2012 Ranger & B-Series
Jun 28, 2012 01:02 PM
870
Dec 27, 2008 05:55 PM
VNAMUS
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 9, 2003 09:50 PM
dherron007
May 1, 2002 07:15 PM
