AC Mod
Old Jul 20, 2008 | 05:26 PM
dcara's Avatar
dcara
AC Mod
I did the air conditioner/heater core bypass mod today. Well almost anyway. I downloaded some instructions awhile back calling out 3/16" vacum line from the vacum tee to the valve switch. Actually I used 3/16" fuel line. However the valve switch plug is smaller. I think it might be a 1/8" so I'll adapt it down later this week. Also, the red vacum line where the tee goes is smaller than 1/8'. Had to do some widening of the red vacum line to get it barely onto the variable tee (minimum 1/8" ) I had. I would also recommend 1" hose clamps for installing the valve switch. 7/8" would only engage the about 2-3 threads and one stripped out the first thread which I had to replaced with a 1" and was much easier.
Old Jul 20, 2008 | 05:32 PM
SpringerPop's Avatar
SpringerPop
Why the red line? Most use the white one.
Pop
Old Jul 20, 2008 | 06:15 PM
kawika's Avatar
kawika
The Vacuum line is 1/8 inch OD and you'll need the 1/8 inch "T" and use some 1/8 inch vacuum line to go over the Red line and connect to the "T". Scared me at first when I cut the Red line and I could not get the "T" on the line. I then cut some 1/8 inch vacuum line and stuffed as much of the red line as I could into it, then cut enough to fit over the "T". I then did the same to the other side (red line). I then placed the 1/8 inch line to the switch.
Read this link here to see some pictures and an added mod to this mod.
Dave..
Old Jul 21, 2008 | 06:15 AM
dcara's Avatar
dcara
Pop
I thinik the white line only engages the valve when you use MAX AC. But the red line engages the valve whenever VENT, AC, or MAX AC is used. I decided I liked this option better.
Old Jul 21, 2008 | 08:30 AM
sideshow's Avatar
sideshow
i originally tapped the red line too. i thought "cool, cold air with just the vent." well the first somewhat warm day this year, the girlfriend informed me (you know what i mean) that i needed to fix that. it was too cold, and i couldn't adjust the temperature. so now i have it in the white line, and it works perfectly. if i have it on max a/c, even with the fan on the lowest settings, it is still almost too cold. that's the shizzle. i had an old '83 s-10 blazer that the a/c was messed up on. only two settings, wide *** open or off. it would actually freeze over the vents if i closed them off.
Old Jul 21, 2008 | 09:59 AM
dcara's Avatar
dcara
I have heard about the no adjust/too cold problem. But I was thinking that was due to a complete shutoff to the heater core. I tested the bypass switch I used (AutoZone #74809) before installaion and noticed it still had about 10% flow thru in the bypass mode. I also wanted to see how well it worked in the normal AC and vent modes. Its hard to imagine any AC being "to cold" in Texas during July -September.
Before this mod my vent gauge said the duct temp is only about 5 deg cooler in MAX AC mode than in Normal. Does anyone know what the difference is between MAX and Normal AC modes. I'm thinking that they just reduce the cycle time on the AC compressor.
Old Jul 21, 2008 | 10:26 AM
SpringerPop
It's just the source of the air to be cooled through the evaporator coil. MAX gets it from the already-somewhat-cooled cabin air, NORMAL takes the hotter outside air.
Some manufacturers call MAX "RECIRCULATE", instead.
Pop
Old Jul 21, 2008 | 11:30 AM
dcara's Avatar
dcara
Cool (pun intended)! I was wondering why the AC did not have a setting labeled "recirculate"
Old Jul 22, 2008 | 05:18 PM
King0581's Avatar
King0581
Been having some vacuum problems and had to unhook mine to be sure that wasnt my problem. Didnt realize how much of a difference it made til it was gone. I wasnt real happy with how cool the vent was so when I put it back its going in the white line, cause thats where that **** STAYS this time of year anyway.
zspeed130
Oct 4, 2014 10:00 PM
87thhunter
Jun 16, 2014 03:02 PM
Slingnsteel
Aug 28, 2013 07:49 PM
dcara
Aug 20, 2012 12:51 PM
Festus Hagen
20
Mar 21, 2011 10:35 AM
