double torque???
its more of a transfer of horsepower and inirtia.
Torque is pure energy.
If you lock up the TQ, you transfer all the torque to the rear wheels.
This is why Manuel will out pull attiematic everday. =)
Most TC systems rely on percentage lockup. Thats why you se rpms drop more than the 4 speeds we have if you have a programmed chip;. I am not sure of it, but I think its like a 15 60 100 type deal. This is how we keep it from burning up. The reson you think it pulls better is that you gear ratios are closer together. TC really has nothing to do with it.
Torque converter will always slip the same.
It's not an adjustable friction base.
I was saying a manual pulls better because there is no TQ slip, allowing all power to go to the rear wheels in lower gears.
TQ's could lock up in lower gears now, but I am totally unsure of that.
Generally you would hear or feel it lock up in a truck if it does at slow speeds with high rpm's pulling something. The difference would be undeniable.
Gear ratio's are another reason behind different RPM's.
So you cannot say it that way.
A different rear end ratio will also make a difference between the rpm's.
I was merly talking about the medium for power transfer from engine to transmission.
You either slip or you dont.
Simple as that =)
However 2strokeman, they missworded what they are saying, which doesn't supprize me on that show. Go watch GEARS, a real enthusiast show. =) Stacey David wont give you BS info.
You cannot "double" your torque from a torque converter.
The only way you are going to create more power is though a gear set, which really your not doubling your power, your just doubling your output.
I think they were trying to say that the torque converter on the allison allows more power to wheel ratio then standard TQ's.
Manuals work better for towing because of gear ratios and the fact that the human brain is better at seeing all conditions.
when a TC locks up, it's just the same as having a locked up clutch. if you go over the rated torque, they'll both slip.
Maybe they were talking about Rated torque... the motor will put out so much, and all the tranny can do is effectively put it to the ground.
The executive summary is to think of two fans facing each other. One has power and one doesn't. The one with power will make the other fan spin from the air hitting it. That's how the impeller and turbine of a torque converter work. In a torque converter the fluid that comes off of the turbine blades it redirected by the stator back into the turbine blades. This energy is what doubles the torque.
As for stepped lockup like 15 60 100, that doesn't make any sense. There's nothing like that. Some torque converters are applied slower, and you may see the duty cycle of the solenoid as it's applying, but it's locked or it isn't.
And as for always slipping the same amount, that's equally wrong. The torque converter slip is a function of how much torque is going through it and how fast it's spinning. More torque equals more slip, and more speed equals less slip.
that's really the only way it could multiply torque, because you cant get energy out of nothing. (stupid laws of thermodynamics...)
that gives a decent explanation of it...
That must have alot to do with the impressive take off on the drag strip...
Secondly this is a quote, and I think you have your 60s chart confused with your 60s TC. here it is " In modern automotive applications, this problem is commonly avoided by use of a lock-up clutch that physically links the pump and turbine, effectively changing the converter into a purely mechanical coupling. The result is no slippage, and therefore virtually no power loss."
Notice the NO SLIPPAGE part.
Furthermore, your statements do not hod true to lockup mode. If running at 45 mph, your motor can almost make PEAK torque without kicking down. Your still at zero slip due to the lockup. When I had to order my converter, ATI insisted that the converter was a one to one. This would mean zero torque multiplication at final. I have yet to check on that. You could be correct on that, but I am thinking not.
I am not trying to be rude, but with these little things, I assume your the one in charge of the tranny coolers on our trucks too????LOL
You completely missed the point of my post. Maybe I wasn't clear enough.
The torque converter is not a digital device. It does not switch from stall to acceleration. It's analog, when the output is held when the truck is not moving it is in stall mode. As it starts to move it goes to accel mode, but that is not a percentage lockup, it's just that the output shaft starts to rotate. The converter is doing the exact same thing, but the input and output speeds have changed and that changes the torque multiplication. As I stated the faster the converter is spinning the less slip there is across the converter, and the more torque applied to the converter the more slip there is.
All of this changes when the torque converter clutch is applied. Then there is ZERO slip. There is also zero torque multiplication. I didn't mention lockup at all because the topic of this thread is torque multiplication. There is none when the converter is locked, so I didn't go there.
And no, I'm not in charge of trans coolers. I'm not in charge of anything at Ford. I quit Ford in February, 2007.
When the engine is spinning much faster than the tranny, the TC acts as a geardown that slowly comes to 1:1 as the two's speed comes closer. it will only completely make 1:1 if the TC locks up.
Sound about right?
