double torque???
Old Jul 20, 2008 | 01:37 PM
2 stroke man's Avatar
2 stroke man
double torque???
ok, so when i thought i was starting to understand a little about an auto tranny, Two Guys Garage threw a kink in my knowledge! they were showing a cut-away of an Allison 2000 auto. they said something about a fluid lock-up for hte torque convertor. ok, i was half way on track till they said that depending on the lock-up system, and torque convertor type that the TC could DOUBLE the engines torque!! how the heck????????????????
Old Jul 20, 2008 | 03:35 PM
Talyn's Avatar
Talyn
You loose all your torque in the TQ.
its more of a transfer of horsepower and inirtia.
Torque is pure energy.
If you lock up the TQ, you transfer all the torque to the rear wheels.
This is why Manuel will out pull attiematic everday. =)
Old Jul 20, 2008 | 09:10 PM
Todd525's Avatar
Todd525
Not true.
Most TC systems rely on percentage lockup. Thats why you se rpms drop more than the 4 speeds we have if you have a programmed chip;. I am not sure of it, but I think its like a 15 60 100 type deal. This is how we keep it from burning up. The reson you think it pulls better is that you gear ratios are closer together. TC really has nothing to do with it.
Old Jul 20, 2008 | 09:32 PM
Talyn's Avatar
Talyn
wasn't saying it like that at all.
Torque converter will always slip the same.
It's not an adjustable friction base.
I was saying a manual pulls better because there is no TQ slip, allowing all power to go to the rear wheels in lower gears.
TQ's could lock up in lower gears now, but I am totally unsure of that.
Generally you would hear or feel it lock up in a truck if it does at slow speeds with high rpm's pulling something. The difference would be undeniable.
Gear ratio's are another reason behind different RPM's.
So you cannot say it that way.
A different rear end ratio will also make a difference between the rpm's.
I was merly talking about the medium for power transfer from engine to transmission.
You either slip or you dont.
Simple as that =)
However 2strokeman, they missworded what they are saying, which doesn't supprize me on that show. Go watch GEARS, a real enthusiast show. =) Stacey David wont give you BS info.
You cannot "double" your torque from a torque converter.
The only way you are going to create more power is though a gear set, which really your not doubling your power, your just doubling your output.
I think they were trying to say that the torque converter on the allison allows more power to wheel ratio then standard TQ's.
Old Jul 20, 2008 | 10:37 PM
Todd525's Avatar
Todd525
TC in lockup mode is not slipping. Its a one to one. If its slipping, then youll see it in your tranny gauge as it will build heat and melt down. If your doubling your tq, your gearing down. Rear end ratio is limiting rpm to speed. 3.55 less rpms, less tq. 4.10s, more rpm, and a torque multiplier. Once these trucks hit about 40 mph, tc is locked in a one to one output. Plain and simple. I was staing that since our autos are 4 speeds and you have a 5 speed and since the final drive ratio is the same, your gear ratio is closer in your tranny. Same as a big truck. This is why a 13 speed is better in the mountains than a 10 speed, even though they have the same final drive ratio. you have more to play with to keep the motor in the sweet spot. If this is what you menat, I am sorry. If it isnt, then now your informed. LOL
Old Jul 21, 2008 | 07:12 AM
Talyn's Avatar
Talyn
Thats what i said. =)
*high five*
Old Jul 21, 2008 | 11:26 AM
secondarychaos's Avatar
secondarychaos
Calm down guys... LOL...
Manuals work better for towing because of gear ratios and the fact that the human brain is better at seeing all conditions.
when a TC locks up, it's just the same as having a locked up clutch. if you go over the rated torque, they'll both slip.
Maybe they were talking about Rated torque... the motor will put out so much, and all the tranny can do is effectively put it to the ground.
Old Jul 21, 2008 | 04:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I haven't seen anything here yet that explains why a torque converter multiplies torque. It does multiply engine torque. HowStuffWorks - Learn How Everything Works! has a good explanation of how it works.
The executive summary is to think of two fans facing each other. One has power and one doesn't. The one with power will make the other fan spin from the air hitting it. That's how the impeller and turbine of a torque converter work. In a torque converter the fluid that comes off of the turbine blades it redirected by the stator back into the turbine blades. This energy is what doubles the torque.
As for stepped lockup like 15 60 100, that doesn't make any sense. There's nothing like that. Some torque converters are applied slower, and you may see the duty cycle of the solenoid as it's applying, but it's locked or it isn't.
And as for always slipping the same amount, that's equally wrong. The torque converter slip is a function of how much torque is going through it and how fast it's spinning. More torque equals more slip, and more speed equals less slip.
Old Jul 21, 2008 | 04:31 PM
secondarychaos
so, does a TC effectively act as a geardown?
that's really the only way it could multiply torque, because you cant get energy out of nothing. (stupid laws of thermodynamics...)
Old Jul 21, 2008 | 04:39 PM
Mark Kovalsky
Yes, the torque converter acts like a gear down. It trades RPM for torque. The more slip across the torque converter the more it multiplies torque. Most torque converters are about 2:1 multiplication at maximum slip.
Old Jul 21, 2008 | 04:55 PM
secondarychaos
Torque converter - Wikipedia, the free encyclopedia
that gives a decent explanation of it...
That must have alot to do with the impressive take off on the drag strip...
Old Jul 21, 2008 | 10:32 PM
Todd525's Avatar
Todd525
Mark, I wholely disagree on many parts here. As stated in the article, there are three stages of function to the TC. Stall, acceleration and Lockup. This represents the three percentages I threw out earlirer. I have no idea where you think it doesnt run in stages, as it hydrodynamic drag overcomes centrifugal force back thru the turbine stator and the pump.
Secondly this is a quote, and I think you have your 60s chart confused with your 60s TC. here it is " In modern automotive applications, this problem is commonly avoided by use of a lock-up clutch that physically links the pump and turbine, effectively changing the converter into a purely mechanical coupling. The result is no slippage, and therefore virtually no power loss."
Notice the NO SLIPPAGE part.
Furthermore, your statements do not hod true to lockup mode. If running at 45 mph, your motor can almost make PEAK torque without kicking down. Your still at zero slip due to the lockup. When I had to order my converter, ATI insisted that the converter was a one to one. This would mean zero torque multiplication at final. I have yet to check on that. You could be correct on that, but I am thinking not.
I am not trying to be rude, but with these little things, I assume your the one in charge of the tranny coolers on our trucks too????LOL
Old Jul 22, 2008 | 07:05 AM
Talyn's Avatar
Talyn
Be good todd.
He wasn't talking about those applications at all.
He was explaning more of the physics part of it.
Old Jul 22, 2008 | 10:36 AM
Mark Kovalsky
Todd,
You completely missed the point of my post. Maybe I wasn't clear enough.
The torque converter is not a digital device. It does not switch from stall to acceleration. It's analog, when the output is held when the truck is not moving it is in stall mode. As it starts to move it goes to accel mode, but that is not a percentage lockup, it's just that the output shaft starts to rotate. The converter is doing the exact same thing, but the input and output speeds have changed and that changes the torque multiplication. As I stated the faster the converter is spinning the less slip there is across the converter, and the more torque applied to the converter the more slip there is.
All of this changes when the torque converter clutch is applied. Then there is ZERO slip. There is also zero torque multiplication. I didn't mention lockup at all because the topic of this thread is torque multiplication. There is none when the converter is locked, so I didn't go there.
And no, I'm not in charge of trans coolers. I'm not in charge of anything at Ford. I quit Ford in February, 2007.
Old Jul 22, 2008 | 11:34 AM
secondarychaos
OK, so in summary,
When the engine is spinning much faster than the tranny, the TC acts as a geardown that slowly comes to 1:1 as the two's speed comes closer. it will only completely make 1:1 if the TC locks up.
Sound about right?
