changing t chain with water pump
Old Jul 19, 2008 | 11:14 PM
46069dord's Avatar
46069dord
ok im buying a edelbrock water pump and was gonna find out if i should go ahead and replace the timing chain set with a pre smog 68-71 timing set while im doin the water pump and is this the right chain Cloyes True Roller Timing Chains - JEGSJEGS High Performance - 220-9-3122 it says true roller doesnt that mean its a double roller? and its pre smog with 3 key way and how hard is this to do anything i should know before i take everything apart any tips?
Old Jul 19, 2008 | 11:17 PM
Ford_Six's Avatar
Ford_Six
I use this,Summit SUM-G6608 - Summit True Roller Timing Sets - summitracing.com and am very happy with it. I used the advanced setting, and can get my loaded trailer rolling uphill by letting the clutch out, no throttle needed. This is on a 360, assuming yours is an FE as well-
Old Jul 19, 2008 | 11:59 PM
46069dord's Avatar
46069dord
o no sir sorry about that its a 460 and i already got the cloyes thanks tho
