electrical problem
Old Jan 3, 2003 | 10:08 PM
joe2705's Avatar
joe2705
Post electrical problem
Hi !
I have a bad problem with my charging system.
First my integral regulator burned.
So I changed the alternator and the wiring but every morning the battery is dead & I DON'T have a proper charge.
I checked everything I could think of for a short,but I couldn't find one.
So, could the alternator be bad?
I checked it with the testlight on the negative cable.
I pulled the wire off the alternator and the light went off.
91' F-250 4x4
Old Jan 3, 2003 | 10:24 PM
Mike W's Avatar
Mike W
electrical problem
Sounds like the alternator is bad. Don't have any info on the newer alternators. I have never seen this problem with the older ones.
Old Jan 3, 2003 | 11:11 PM
steve83's Avatar
steve83
electrical problem
Most parts stores will test alts free on or off the vehicle. Take it to a couple, and THEN to the one where you bought it. Don't tell any of them what you're doing - just ask them to test it & thank them when they're finished. When the supplier finishes his test, tell him the symptoms you're having & the results of the other stores' tests & see what he says.
Old Jan 4, 2003 | 01:32 AM
rebocardo's Avatar
rebocardo
electrical problem
Robber80
Dec 12, 2018 05:33 PM
maximumd93
Mar 11, 2013 09:52 AM
kenrat
1983 - 2012 Ranger & B-Series
Aug 24, 2009 09:15 AM
roller_steve
Oct 17, 2008 10:57 PM
