broken slip yoke
Old Jul 18, 2008 | 07:20 PM
deeznuts822's Avatar
deeznuts822
broken slip yoke
Anybody ever seen one snap? Mine broke when i was backing up with a load of wood? What exactly is it called? Its the one that goes into the transfer case on the rear shaft
Old Jul 18, 2008 | 07:59 PM
gweeds's Avatar
gweeds
It happens... You should be able to pull the old one out and replace it with a new one. Pick one up at the local scrap yard if you are feeling inclined. Its a good opportunity to replace the u-joints while you have the drive shaft out.
Was is rusted or in really bad shape?
Old Jul 18, 2008 | 08:02 PM
danr1's Avatar
danr1
Yea Its call a slip yoke or slip yoke assembly and yea they break.
Question is did anything else brake, is the tail housing OK? They tend to crack when that happens but doesn't mean yours did.
Look it over good and if you see nothing else wrong I just pick up a replacement shaft at the bone yard.
You could put a new yoke on your shaft but it may be bent now, either way its a trip to the bone yard.
If needed replace the u-joints before you put it back in. May have been a bad joint that caused the failure to start with.
Old Jul 18, 2008 | 08:24 PM
deeznuts822
broke where the u joints go, it kinda looks like it might have been cracked, 3 nice clean breaks and one old oily one. joint isnt broke but i lost a cap.
Old Jul 18, 2008 | 08:49 PM
danr1's Avatar
danr1
Oh that part broke, thought you ment the spline area snaped.
Yea I'd just get a complete "used" shaft from a bone yard for 50 bucks. The cap "loops" may be bent all out of shape/alignment now if it let go completely. If bad enough you'd be replacing u-joints all the time.
mudguts
May 21, 2016 04:52 AM
bradphx
Mar 26, 2016 07:18 AM
71Nky
21
Mar 8, 2015 09:48 PM
helifixer
Arizona Chapter
519
Jan 20, 2013 06:10 PM
Moneyhill1958
Jul 11, 2002 10:03 AM
