6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
soot in tailpipe
Old Jul 23, 2008 | 09:21 PM
  #46
Lead Head's Avatar
Lead Head
Originally Posted by vloney
Fix What? Soot in the tailpipe DOES NOT mean theres something wrong. Smoke out of the tailpipe means theres something wrong. Theres been a lot of dealers that have had the cost of dpfs charged back to them for replacing them unnecessarily. When you replace something under warranty, you have to send it back to ford for their engineers to inspect. Again, if it aint smoking, it aint broke! If we started that, we'd have "my buddies truck gets 15 mpg, mine gets 14, I demand you fix it!". If it doesn't show insufficient backpressure, if it doesnt show fuel leaks, if the oil level is ok, if its running ok with plenty of power.......What do you fix? Do you randomly start changing parts?
Obviously something is wrong if almost everyone else has completely clean tail pipes, and people that have had sooty tail pipes change the DPF's out and cleaned the tail pipe, and they never got sooty again. When ford themselves had demo videos of them wiping a cloth in the exhaust pipe of a 6.4 to show how there was no shoot, I'm pretty sure that points to something being wrong. Just because you can't see the smoke doesn't mean its not making any.
Old Jul 24, 2008 | 09:49 AM
  #47
richfaa's Avatar
richfaa
The DPF literature says that 93% or better of "soot emission " should be burned off in the regen process. My tail pipe was filled with thick black soot and since replacement has been completely soot free. That means when I run my finder inside the tail pipe it does not have any black on it at all. if "it aint smoken it aint broke " is not entirely correct. What most likely is correct is that Ford or the dealerships are not training their diesel tech's in the proper procedures to diagnose DPF problems.
Old Jul 26, 2008 | 08:30 PM
  #48
GM243's Avatar
GM243
I have 5000 miles on my 6.4 and there are no signs of soot yet. Though now i am scared after reading this. My question is that a few responses back someone said that this engine will not meet the 2010 requirements. Is this true? If so then what do i do with my truck in 2 years?
Old Jul 26, 2008 | 08:42 PM
  #49
F350-6's Avatar
F350-6
No your truck will not meet 2010 emissions, just like my 7.3 or the 6.0's won't meet 2008 emissions. The requirements are for vehicles manufactured in 2010 or later.
Your truck will be fine with no modifications or upgrades required.
By the way. Welcome to FTE.
Old Jul 27, 2008 | 10:08 PM
  #50
GM243's Avatar
GM243
So does this mean that i must smog my truck later? If not then why not get rid of the dpf? I thought that it was for trucks manufactured after jan 1 2007.
Old Jul 27, 2008 | 10:12 PM
  #51
caprang's Avatar
caprang
My truck has 900 miles on it, tail pipes are dark, not completely black, but definitely soot. I have NEVER seen a regen. Its a job#3 so the message center should tell me its in regen. I have watched for signs of a regen, watched the message center, etc, and have not seen any sign of a regen. 90% of my driving is towing so I thought the EGT's were high enough to keep it clean but now that I am seeing soot in the tailpipe and still no regen I have to wonder.
Old Jul 27, 2008 | 10:13 PM
  #52
Lead Head's Avatar
Lead Head
The emissions standards compliance rules are no different. Your truck just has to meet the emissions of the year it was made. So as long as your truck meets 08 emissions, your golden.
Old Jul 28, 2008 | 12:41 PM
  #53
richfaa's Avatar
richfaa
Caprang....You have a problem..most likely a cracked DPF.
Old Jul 28, 2008 | 08:56 PM
  #54
GM243's Avatar
GM243
I have about 5500 miles on my truck and i have only noticed 3 regens on the message center and i have no signs of soot or darkening.
Old Jul 29, 2008 | 10:12 PM
  #55
Moyerboy's Avatar
Moyerboy
Ok well i have been watching my exhaust smoke and it seems to be getting worse the computer says 14.9 and im getting around 14.5 to 15 by the old calc but the smoke jsut gets worse everyday and no regens so all i can do is wait til it locks up and then get it fixed. Thanks guys peace out
dtwillie
Sep 19, 2016 02:40 AM
vtpkrat2
1997 - 2003 F150
May 27, 2016 09:46 PM
7.3 Powerstroke Guy
Feb 1, 2016 10:02 PM
Larry85355
Aug 7, 2014 06:08 PM
thebbp
1978 - 1996 Big Bronco
Jul 1, 2001 01:47 AM
