unhappy starter---help!!!!!
Old Jan 11, 2003 | 04:00 PM
marine 1's Avatar
marine 1
alright'y then, i have a 1987 F-250, w/ 6.9 diesel 4X4, it started to get hard to start, and when it would it would run for 10 sec, then die, after turning it over for a while eventually it would start again....well i've replaced the batterys and now it turns over real slow... i was told the starter is dragging and i need a new one..ouch, there like 200 bucks, does any one have experience rebuilding these thing's or a suggestion...200 on top of a new transfer case and everything else...soon i'm gonna have ta start eatin' CAT FOOD......THANKS
Old Jan 11, 2003 | 06:32 PM
Bob Ayers's Avatar
Bob Ayers
You may have overheated the starter..Make sure you fix the "hard starting"
Problem first, which is probably the glow plug relay.....
Old Jan 12, 2003 | 10:32 AM
rebocardo's Avatar
rebocardo
Well, this means it is not starter related. It is glow plug/warm/cold fuel related. I have never worked on 6.9L engines, just tractors (trailer). What it sounds like is that the glow plugs are being properly heated, the truck starts, then dies because the fuel/air combo is too cold to support combustion.
On your truck there is probably a relay turning off too early (or not coming on at all after the glow plugs do their work) that is suppose to keep the fuel, glow plugs, or air hot until the engine warms up. I would bet if you plugged in your block heater the truck might run longer until it got hot enough on its own (engine speed 1250 rpms for five minutes) to support combustion.
Old Jan 12, 2003 | 02:47 PM
TryMe's Avatar
TryMe
Los_Control
24
Apr 3, 2017 09:34 AM
dwalphinVT
Mar 4, 2017 12:01 PM
tigers2007
20
Jun 22, 2016 10:03 PM
David LaPell
Jan 6, 2014 12:12 PM
Greenlawnracing
Jan 2, 2009 02:53 PM
