Temp Gauge sending unit?
Old Nov 14, 2002 | 08:01 AM
brianbarbva's Avatar
brianbarbva
I just did a flush and fill on my 87 Bronco 2 4x4 and ever since the temp gauge has red hot. I want to check and replace it if need be but where is it located on the block?
Old Nov 14, 2002 | 10:28 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
On a carburated a small block like a 5.0 or 5.8, the sending unit is screwed into the intake manifold between the distributor and right valve cover as you look at the engine. On a fuel injected engine it may be in a different location, but it is probably still on the intake manifold. It should be a 1/2" threaded plug with a single wire going to it.
Given what you said about running hot right after the cooling system flush though: First recheck the coolant level in the radiator. When the cooling system is completly drained a lot of air will be trapped in the block until the thermostat opens. Then the coolant in the radiator will displace the air from the block, but the radiator level will now be low and the engine can overheat.
Old Nov 15, 2002 | 06:42 PM
brianbarbva
That is the first thing I checked, no it goes to the hot side of the gauge as soon as the key is turned.
Old Nov 15, 2002 | 08:22 PM
Mil1ion's Avatar
Mil1ion
If it *Pins* to the right hand side,it means the wire to the S/U is shorted to ground.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 16, 2002 | 12:18 AM
sparky's Avatar
sparky
[updated:LAST EDITED ON 16-Nov-02 AT 01:21 AM (EST)] Still could be the sending unit, seen them before internally "screwed"
Although I dont know where the sending unit is on a 302EFI version
Sparky
ps
After you locate the sending unit...disconnect the wire on it and while making sure it doesnt touch anything turn the key on. If the guage still pegs it is most likely the wire ...if it stays at cold the sending unit is toast.
Old Jan 13, 2003 | 08:18 AM
STEVELAKE's Avatar
STEVELAKE
I have a Ford, 1990, E-150, with a 302 engine.
I cannot locate my temp. sending unit for the temp. gauge.
Please advise me.
Steve
Akron, Ohio
Old Jan 13, 2003 | 01:52 PM
honney's Avatar
honney
http://www.superford.org/registry/vehicles/users/71/50/coolsend2.jpg
http://www.superford.org/registry/vehicles/users/71/50/dashsend.jpg
Old Jan 13, 2003 | 05:47 PM
The Baron's Avatar
The Baron
