Over Loading Headlamp Switch
Jan 12, 2003 | 07:54 PM
I have just purchased a 1990 F350,It has a Toggle switch under
the dash area to switch on the running lights, the guy I bought
it from said it was to stop over load on the main switch, as its
a little untidy I wondered if any one has a circuit or suggestion of a wiring diagram to fit a solinoid in the system, or any other
suggestions as to make the whole thing back to standard.
Jan 12, 2003 | 08:23 PM
Just go back to the normal switch way but,do a upgrade to the headlights on a relay instead.
This should take all the resistance out of the headlight switch from the running lights
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Jan 12, 2003 | 10:20 PM
I think I understand what you are saying but could you give
a Diagram to explain where a relay would go ?
Jan 12, 2003 | 10:29 PM
[updated:LAST EDITED ON 01-12-03 AT 11:30 PM (EST)] This tech article may be able to be adapted to your truck
https://www.ford-trucks.com/articles/delanty/brighter_lights.html
Sparky
Jan 13, 2003 | 09:29 AM
HEY sparky,
GUESS THAT'S solved that PROBLEM .
thanks
Jan 13, 2003 | 01:15 PM
Sorry about leaving you stranded, til sparky showed up Baron.
I have many things going on, and ran out of time when typing.
When you purchase relay's,make sure you buy the Bosch relay's,they are of higher quality than most.
Dennis
Jan 13, 2003 | 05:47 PM
Hey Mil1ion,
I understand time is an element of truth hard to come by sometimes.
Will take you advice about Bosch Relays.
THANKS for the tip
Jan 13, 2003 | 06:19 PM
Big Smoke
Oct 19, 2015 08:44 AM
mwells
Dec 29, 2014 09:13 PM
H20ENG
19
Feb 21, 2013 09:21 PM
lowbrow88
Jan 3, 2013 07:12 PM
GammaDriver
Electrical Systems/Wiring
Nov 8, 2006 09:40 PM
