"Warning" against 6637
Old Jul 17, 2008 | 11:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by UP_There
Too many people talk smack about things they just don't understand!
I think you hit the nail on the head, Travis.
Old Jul 17, 2008 | 02:34 PM
nlemerise's Avatar
nlemerise
ALERT!!!
Hey Travis...were you separated at birth from Rick of Ice Road Truckers? I submit for everyones perusal, the photos below:
Travis is on the left, Rick is on the right.
Old Jul 17, 2008 | 02:56 PM
sealboy84's Avatar
sealboy84
Originally Posted by randomhero1172
Was at the shop of a very well known mechanic and diesel man today who was working on my truck. He has a duracrap that puts out some nice numbers and does tuning for sled pull trucks and stuff like that. He commented on my 6637 "I highly recommend that you change filters, the paper from the inside of the filter can be sucked off during high boost" Something along those lines. He said a fiber/oil element is the only way to go - but make sure you keep it oiled! He said he has seen these filters eaten from the inside out from the turbo sucking so hard. Any one buy this? Im a little skeptical ...
I wonder if the the guy has a brother that lives here in New Mexico. He didn't go as far asto say that I would suck paper, but he said that there was no way that a paper filter would filter as well as his K&N. Then he dropped the bomb "Well don't think that just because I'm a K&N dealer..."
Thats about the time that my selective hearing switched on.
Old Jul 17, 2008 | 03:06 PM
redfire42's Avatar
redfire42
Take it with a grain of salt, he was a dmax owner, our filter is bigger then his, jealousy maybe?
Old Jul 17, 2008 | 03:11 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I suppose me pointing this out is really BS, but is that not what I implied a few posts back?
Old Jul 17, 2008 | 08:43 PM
randomhero1172's Avatar
randomhero1172
I never thought this guy was right at all - was just curious if anyone experianced this or has heard this from other people. I trust any of you guys with what you tell me, i never second guessed the great minds at FTE
Old Jul 17, 2008 | 09:03 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
how bout me running upwards of 40# of boost and still have 6637 in one piece. did few runs over 120mph still in one piece. did dragracing and it still survived...
so i would not worry about 6637 , K&N is junk and they can run them on Duracraps . LOL
Old Jul 17, 2008 | 09:39 PM
John311t's Avatar
John311t
Running a year and a half plus on my 6637 filters. Im on my second one now, and my intake has never been this clean. When I took off my intake tube recently(its been a LONG time before that), it was clean. I wiped my finger in the tube and nothing was in there at all.
I think running compounds it might decide to eat the filter, but at up 50PSI, I would think that filter would be fine.
Where was this duramax guy located?
Old Jul 17, 2008 | 09:45 PM
sflem849's Avatar
sflem849
Originally Posted by 1996pwrstrk
I have been running 6637's on my last 2 psd's and have no such problems and mine will pull upwards of 34 lbs of boost. Over the road big rigs have been running the same style paper element for many many years with no problem.
I have to disagree with your big rig comment. The OTR trucks run this type of filter in its designed format. We are taking a element that was designed to be ran in an "air box" setup and running it as an open element. This air box design will almost certainly keep the filter dry. The only time I see a wet filter is if the canister started rotting away.
If a 6637 were to get water on it I could certainly see it peeling apart from the inside. This is the reason some suggest using the 46637(???) that was designed for the marine applications. It has some sort of waterproofing. I here the reason most don't use this is bc of the price (about twice as much) and not everybody has heard about it. If anyone knows more than this or can correct me please do. This is all hearsay info with no data to back it up.
Old Jul 17, 2008 | 09:50 PM
sflem849's Avatar
sflem849
Originally Posted by twags6
Well if that were true, you'd be much more likely to suck the paper off a stock filter cause its more restrictive. Not saying it couldn't happen, but it could also happen to the filters he recommended.
I disagree, the stock paper filter is a wierd sort of paper compared the the 6637 paper. Get each of them wet and I could be the 6637 will flake off in layers first.
Old Jul 17, 2008 | 09:52 PM
jdecker88's Avatar
jdecker88
I believe your duramax man was just trying to sell you on his stuff, he's just jealous because you suck in more air then he can with his headlight off . I have ran a 6637 for well over a year and it works well and cheap for me, it looks really great with a Pete's cover.
Anyone that is a salesman will always tell you their stuff is better, about like a Superchips dealer told me my DP-Tuner was junk because any chip you put into the back of your PCM was just asking for trouble and they couldn't provide the safe EGTs and power of his superchips.
Old Jul 17, 2008 | 10:59 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Uhhmmmm, how about no, Scott, OK. Sorry, couldn't resist that line. I have no facts to back that up, but know my truck has been running the 6637 for about the last 5 years. No problems.
I have seen my block/engine dripping with water from the humidity (condensation) in the AM before startup. That filter is about saturated but no problems. IDK what you may be talking about.
Old Jul 18, 2008 | 06:30 AM
  #28
sflem849's Avatar
sflem849
I ran NAPA Gold (Wix) filters in my stock air box and they always had some sort of yellow treatment on the paper. They almost seemed like an oiled paper to me. I took one apart one day when I took it off and they seemed different. Not your typical flaky layer type media, they were really bonded together.
Old Jul 18, 2008 | 09:10 AM
  #29
Pocket's Avatar
Pocket
You could always show that guy the pictures in this thread. It's the latest turbo damaged from using a K&N filter: Installed my DIY intake and I have nicks on my turbo! - The Diesel Garage Forums
Oh, and as for getting the 6637 wet. Short of opening the hood and dumping a bucket of water on it, you won't get it wet. I ran it for several years in my truck, and driving through snow/mud/rivers/etc not once did it get hit with anything. Stayed dry as a bone. Humidity doesn't affect it either. I've driven down to the darkest swamps in Louisiana.
Old Jul 18, 2008 | 12:42 PM
  #30
UP_There's Avatar
UP_There
Originally Posted by nlemerise
ALERT!!!
Haha.....I don't know what Ice Road Truckers is.....but he's a lucky guy!
