Oh, and as for getting the 6637 wet. Short of opening the hood and dumping a bucket of water on it, you won't get it wet. I ran it for several years in my truck, and driving through snow/mud/rivers/etc not once did it get hit with anything. Stayed dry as a bone. Humidity doesn't affect it either. I've driven down to the darkest swamps in Louisiana.
I live 12 miles from the Gulf, in the middle of marshes. Don't have swamps in south west La. I am suronded by marsh, and never had a problem with the 6637. Dry as a bone.
If a 6637 were to get water on it I could certainly see it peeling apart from the inside. This is the reason some suggest using the 46637(???) that was designed for the marine applications. It has some sort of waterproofing. I here the reason most don't use this is bc of the price (about twice as much) and not everybody has heard about it. If anyone knows more than this or can correct me please do. This is all hearsay info with no data to back it up.
just want to point out that 46637 is the Wix number for the 6637 and is the same thing (litterely the same since the napa 6637 is made at the same plant) so the marine application must be a different number.
I have to disagree with your big rig comment. The OTR trucks run this type of filter in its designed format. We are taking a element that was designed to be ran in an "air box" setup and running it as an open element. This air box design will almost certainly keep the filter dry. The only time I see a wet filter is if the canister started rotting away.
The OP made no reference to the filter getting wet only that it would come apart at high boost so the comment with the comparison to the big rigs I believe is still valid , I used to get 75,000 miles or more out of the twin filters on my Pete and even though the were enclosed Im sure they got wet more than once . I believe but I'm not positive that most paper elements like these have some water resistant coating , I mean they won't take a full on blast from a water hose but running down the road in the rain it won't soak it up.
I know there was no reference to the filter getting wet and that is why it was coming apart, but I think that is the ONLY way it could happen. I think moisture is just something we have to be mindful of when running a 6637.
I will do some searching when I have more time on what the marine application number is. I know it was similar with one digit added or changed or something like that.
well, if you did want to change it, the alternative is the AFE version of the 6637,
im currently running one, and the sound is sweet, it also has a conical head vs. the flat top head on the 6637, pm me for details.
I'm guessing you mean normal air pressure at sea level. In fact, when the trucks running, its seeing a vacuum.
Right. And even if the truck were able to pull a perfect vacuum (which it won't), the most pressure that would be on the filter element would be atmospheric (~15 psi).
So the question might be, can this filter element withstand 15 psi under all conditions? I think it can.
