Dimming Dash
Old Jan 14, 2003 | 05:30 PM
truckfreak69's Avatar
truckfreak69
Dimming Dash
When at idle, especially with the brakes on the dash lights dim, as does my tach (the tach gets power through a wire i stuck inside the fuse box in an accessory fuse terminal, probably not the wisest way to wire that but the only way i knew how to get it to light up and dim with the dimmer switch). As soon as i hit the gas they brigthen again. What could be causing this and how do i fix it, when i replaced the alternator they were out of the higher output one i had before so i went for the smaller one, could this or my battery be the problem or what is the deal. Someone said to check my grounds but how do i go about this?
Old Jan 14, 2003 | 06:17 PM
Mil1ion's Avatar
Mil1ion
Dimming Dash
What is your Idle speed?
600,550 or less In drive ?
This is normal with too low an idle.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 15, 2003 | 02:10 PM
truckfreak69
Dimming Dash
whatever teh stock EFI sets it at, i think around 5-600 according to my tach
Old Jan 15, 2003 | 02:11 PM
truckfreak69
Dimming Dash
is it normal for them to go brighter, darker, brighter, darker..... at idle? cus it wouldn't bother me so much if they just dimmed but they friggen change lol it drives me nuts
Old Jan 15, 2003 | 02:16 PM
beartracks's Avatar
beartracks
Dimming Dash
steveg_nh
Mar 5, 2017 07:25 AM
ddeflyer
Feb 9, 2016 01:49 PM
adamlpc80
2015 - 2020 F150
Dec 8, 2015 09:58 PM
biglou96
May 10, 2015 08:18 PM
Raptorgabe
6.7L Power Stroke Diesel
Jun 16, 2014 08:00 PM
