Is anyone interested in installing a one touch down module on their passenger window. I've done this before on my 93 F150 and am now going to do this to my 94 Mark VIII and 95 Taurus. I'll give instructions if someone is interested.
[updated:LAST EDITED ON 11-Sep-02 AT 03:25 PM (EST)]I have a Ford F-150 XLT would like to know about the One Touch Down Module for Passenger Window. Will it work on all Power Windows? Can you help me with this problem?. I have a keyless entry With Panic Alarm. Is it possible to use that alarm system, when door is open, to set off alarm. Can it be wired in such a way?
mjb41847(No Email Addresses In Posts!)
I have a 93 F150 XLT to which I have installed one touch down modules on both windows. I used the modules that were made for a 94 Lincoln Mark VIII. I used these modules because I had the information for them. I now have the information for the modules in a 95 Ford Taurus. They would hook up exactly the same way. I suspect that any Ford one touch module would work. I can give written instructions for how to hook these up. It will probably take me a couple of weeks to find the time to do it. I may be able to take pictures of my installation.
I'm not sure what you are referring to about your alarm system. Could you please give me more information?
[updated:LAST EDITED ON 01-12-03 AT 03:24 PM (EST)]Hi, would you happen to have the pinout on that Ford one touch down module? Mine is a five pin. 2 big pins and 3 smaller pins. Please let me know. Thank-you!
Pin 1 - goes to motor, has 12 volts when going down, 0 when going up.
Pin 2 - goes to switch, has 12 volts when going down, 0 when going up
Pin 3 - goes to 12 volt with ignition on
Pin 4 - goes to switch, has 0 volts when going down, 12 when going up
Pin 5 - ground
