Aerostar Ford Aerostar
Climate vent switch not working
Old Jul 16, 2008 | 11:35 PM
Zen Punk's Avatar
Zen Punk
'93 3.0L w/AC
The selector switch(for switching between vent, defrost, floor, etc.) seems to have stopped working completely today and I'm not sure where to start on fixing it. The fan will still turn on when you move it away from "off," but air will only come out of the defroster vents, no matter what position you move it to.
Anyone had this problem before? Know what areas I should look at? Is this likely a problem with a wire, a switch, a relay, a motor or a door?
Are the climate doors in the post-92 aeros mechanically, electrically, or vaccuum operated? If it's vaccuum, where is the vacuum supply hose located on the side opposite the engine?
Thanks guys, this is a real killer in this heat.
Old Jul 17, 2008 | 12:25 AM
Mormakil's Avatar
Mormakil
Check under the glovebox, a white colored vacuum line often gets disconnected, causing defrost only. If not under glove box, trace vacuum lines first to eliminate the easy stuff.
Old Jul 17, 2008 | 01:11 AM
xlt4wd90's Avatar
xlt4wd90
Also check under hood for the vacuum lines around the air box. They are tiny plastic lines, and will crack with age and heat.
Old Jul 18, 2008 | 09:19 PM
Zen Punk's Avatar
Zen Punk
It works now. I found the vacuum line for the climate system. I disconnected it from the intake when i was working on it earlier. Thanks guys!
