UPDATE: Got water pump off, and...
couple questions:
1. Where can I find spare bolts for the timing cover/WP? I broke four or five.
2. The top part of the timing cover seems to want to come loose. the bottom does not. It seems to fit into a groove on the oil pan. Must I remove 3 or 4 bolts each side, on the oil pan, first? I tried removing the first and loosening the 2nd and 3rd, each side. Couldn't get it free. Hate prying on the flexible soft oil pan mating metal. Any tips? You can't drop a center link like you could on a GM, for easy pan removal. there's the damn 'twin I-beams' to contend with.
3. Last, which aftermarket repair manual would be best for my truck: Haynes or Chiltons. (I used to prefer Chiltons, but for this truck, maybe Haynes is better??) Would love to get hold of a factory service (shop) manual, but these things are hard to find.
2. The front oil pan bolts usually thread into the bottom of the timing cover, not the block. What motor is this?
3. Both suck, pick your poison. A Ford shop manual would be best as you implied; often you can find them through eBay or on CD from misc. vendors. Either one of those books will have enough information to do your project.
Assuming it is a FE engine, you have to remove 5 or 6 bolts from the front of the oil pan. They bolt into the timing cover. There is one on each side and I believe 3-maybe 4 on the front. The timing cover gasket set will come with a replacement gasket for the pan to timing cover. A little silicone in the corners and you should be good on the replacement.
I would think the two alignment dowels in the front of the block, that align the tc are forceing the tc against the rubber gasket and oil pan. Those dowels are about 1/4" diameter, and the tc plate itself is about 1/8" thick so that will be a tight fit-not to mention the gaskets holding it and corrosion. It should be tough to get out, but not impossible, and I don't think you will need to drop the pan.
If you think the pan to block gasket is comprimised just degrease it and try to smear some high temp silicone into the gap and button er up. Provided there are no chunks of pan gasket falling out or in.
+1 on the bolts and manual.
When/if you replace your timing chain-make sure the replacement doesn't have the nylon cam gear teeth-not the best for reliability, and hopefully they have been phased out for the good ol all metal timing set.
Also check your timing cover for corrosion pits where the waterpump sits. Some pitting is ok, of course you don't want it through because that means coolant in the crankcase.
Hope it helps, good luck!
What's there instead is a flat steel plate (D6AZ-6B070-A), which Ford calls a "Cylinder Front Cover Plate."
Mechanical fuel pumps are normally mounted on timing covers, but on these engines, the fuel pump bolts (at 12 & 6 o'clock) on the drivers side of the engine block.
Hardware for the cover (as listed in the parts catalog):
3) 383963S .. Bolt (plate and waterpump to block). Hex washer head: 5/16" -18 x 2 29/32."
4) 372995S13 .. Screw & Washer (plate to block). hex head: 5/16" -18 x 3/4."
4) 42789S8 .. Screw & Washer (plate to block). Hex head: 5/16" -18 x 3/4."
3) 56121S .. Bolt (plate to block). Hex washer head: 5/16" -28 x 7/8." greensalescompany.com has these bolts: 800-543-4959
I searched the internet and the dealers inventory for these parts, only found one part number.
All this hardware is obsolete.
But...you might luck out at your local dealer, because most dealers don't throw hardware away, it's usually not on inventory (dollar wise), so it may lay unused in drawers for decades.
The same hardware was used on 351C/351M/400: 1970/79 passenger cars / 351M/400: 1977/82 F100/350's / 1978/82 Bronco's / 1980/82 Econolines.
Ford shop manuals: helminc.com has some new factory Ford originals available for late 1970's F100/350's. Helm has printed all of Ford's literature for 60 years.
faxonautolit.com sells original and reprints of original Ford shop manuals, owners manuals, sales brochures, you name it.
Let me say that I do not need any bolts that only attach plate to block (and don't go thru water pump). The only ones that broke were ones that went thru WP. Also, I count 11 bolts that go thru waterpump and plate to block. There are 4-6 (I forget whether it's four or six) more holes on WP alone, that attach AC and PS brackets. Also, the top most bolt, the one right under the vacuum advance for the distributor, technically does not thread into block. It's a bolt that attaches WP to the plate only.
Anyway, here's what I have for bolts, starting with the very top bolt, the one right under the distributor vacuum advance and going around clockwise:
1. Bolt, 5/16-18, hex washer head. Length: 1 1/4 inches.
2. Bolt, 5/16-18, hex head. Length: 1 23/32 inches. has a split washer
3 & 4: same as #2.
5. Bolt, 5/16-18, hex washer head. Length: 2 27/32 inches.
6. same as #5. #5 and #6 are on top and bottom of lower radiator hose outlet.
7. same as #1.
8. Bolt, 5/16-18, hex washer head. Length: about 3 inches (but has other washers stacked) to make its 'effective' length about the same as #5 and #6. Interestingly, the bolt head size is only 3/8"!! Talk about a small head on a large bolt! I'm thinking this may not be original. It's one of the two bolts that also hold on the alternator bracket (and goes thru WP, plate, into block).
9. like #2,3, and 4
10. like #2,3,4, and 9
11. Bolt, 5/16-18, hex washer head (but has other washers stacked). This one is nearly same as #8, except the head size wasn't a 3/8 but rather, a 1/2" like all the rest of the bolts. this one is the other bolt that holds alternator bracket onto WP, goes thru WP, plate, and into block.
The bolts that are broken are: #1, #3, #9, #10, #11.
Do these sizes and things sound correct?
There are three bolts that hold just the plate to the block (and don't pass thru WP): two are shouldered studs that hold on the timing advance strip plate, one is a short bolt closer to bottom of plate.
Apologies for a long post.
