Growling
Old Jul 15, 2008 | 07:28 PM
fastmaster's Avatar
fastmaster
Growling
I have a 1999 Explorer v6 with 113,000 miles. At 40mph theres a growling noise coming from somewhere.I replaced the complete rear end 2,000 miles ago due to a worn out r&p with a used one with 68,000 miles we took it a part to check it out and everything seamed fine. I cant tell if its the front or rear making the noise it only makes it around 40. Any ideas?
Old Jul 18, 2008 | 12:25 AM
mercman86's Avatar
mercman86
jack the truck up and spin each wheel. the most likely culprit is the wheel bearings. i had the same problem on my sisters 96 XLT V6 4X4. and of course it happened right after i put breaks on it so she assumed i screwed up (yea right). the front wheels were covered in a fine powder of metal and both front wheel bearings were shot. they were pretty easy to change on the 4x4. unplug the wheel speed sensor, remove 4 bolts and the whole assembly slides off, and the new one slides right back on. i didn't have a problem with the rears though. but every early (92-99) explorer with a growling noise that ive seen has been the front wheel bearings. hope this helps!
Old Jul 19, 2008 | 05:52 AM
ccecilm2's Avatar
ccecilm2
I vote for a front wheel bearing problem also. I had the same problem with my 99 MM.
Old Jul 22, 2008 | 04:38 PM
fastmaster's Avatar
fastmaster
I figured out it was a front hub so were going to replace both. Theres a dust seal on the back side of the hub should I repalce them?
brianjordanf250
Apr 28, 2013 10:23 AM
faxmonkey
Jan 29, 2013 02:58 PM
rednekrebel28
Mar 7, 2010 09:22 PM
jim4
Nov 10, 2009 10:14 AM
gard107
Jan 8, 2009 03:43 PM
