7.3 coolant flush
Old Aug 27, 2010 | 11:58 AM
fatjoe8504's Avatar
fatjoe8504
Thanks you guys. It's cool to be in a community of truck owners who are all about helping each other
Old Aug 27, 2010 | 12:23 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by SteveH-CO
I think the only Prestone you can now buy says 'All Makes, All Models' - which means it's OAT, which means it's not correct for an '01 7.3, correct?
I read a Motor magazine article on coolants and am now more confused than ever. There are very few 'old style' antifreeze products sold at chain auto parts stores. They mostly have premixed and $#@%^ Dexcool/OAT stuff. The only 'ELC' I found at a Pep Boys was premixed, $20/gallon, and they had a whopping 2 gallons in stock.
Prestone makes a heavy duty extended life coolant. It comes in a black bottle.
Don't get anything that say's Dexcool. It's not made for our vehicles, it's made for GM vehicles.
ELC's are not easy to find at "normal" chain parts stores. People usually go to a lubrication point of sale outlet, like a Chevron or Cat dealer. Walmart and Napa usually sell ELC's too.
Stewart
Old Aug 27, 2010 | 01:07 PM
bama29fan's Avatar
bama29fan
Stewart
thats what i used...Prestone heavy duty heres a link...its the 8th one down....they also have the 50/50 mix for topping off.
Antifreeze / Coolant | Products | Prestone®
Old Aug 27, 2010 | 01:14 PM
bama29fan's Avatar
bama29fan
Yes it is.
See my link below for pictures.
Or, instead of posting a link to another site, you can post a link to the thread I created here at FTE that has pictures.
https://www.ford-trucks.com/forums/9...ml#post8935201
Stewart
lol...sorry stewart. i was in a hurry and had the other link saved as a favorite (from before you did your thread). i'll try better next time
Old Aug 27, 2010 | 01:37 PM
SpringerPop's Avatar
SpringerPop
Yes, it is. VERY cool!
Pop
Old Aug 27, 2010 | 03:51 PM
Stewart_H's Avatar
Stewart_H
Stewart
Old Aug 27, 2010 | 11:50 PM
ScaldedDog's Avatar
ScaldedDog
I just did this to our Excursion after fuel from a leaking injector cup contaminated the coolant. I've got a comment and a question:
Comment - If you're going to remove the passenger's side drain plug without removing the starter, and that's the right way to do it, disconnect the batteries. Otherwise, you'll shower yourself with sparks when you accidentally touch the wrench to the starter wire.
Comment - I used 3g of Simple Green to get the fuel out, and that worked great. The Simple Green was a royal pain to remove, though. After many flushes I finally gave up used the VC-9 procedure, which worked.
Question - What can I do with the VC-9 and distilled water that I drained? It's black, presumably from the metal deposits the VC-9 removed. Our local sewer district won't let us pour antifreeze in the toilet, so I'm sure this stuff is off limits for that, too. The local antifreeze recycler won't take contaminated antifreeze, and so won't take this. Any ideas?
Thanks,
Mark
Old Aug 28, 2010 | 12:42 AM
Stewart_H's Avatar
Stewart_H
No offense, but that is NOT the right way to do it.
Removing the starter is not necessary at all, and you don't have to disconnect the batteries. If your near the starter wire, you're doing it wrong.
You access the passenger side plug by going up the side (well behind the wires) and over the starter.
Properly accessed, a person is just nowhere near the starter terminals and wires.
I've done this three times now, so I'm pretty familair with the procedure, and removing the starter is just a waste of time and energy.
You're a brave man. You actually put Simple Green in your engine and used it to flush your block?
Wow. I know the six-leaker guys do it, but I'm not sure I ever would.
Not knowing much about VC-9, I would think you probably have to use it once you used the Simple Green.
You got me bud.
Stewart
Old Aug 28, 2010 | 12:39 PM
ScaldedDog's Avatar
ScaldedDog
Agreed, and I figured that out just after my spark shower. I'd still disconnect the battery, as it's just too easy to accidentally touch the uncovered starter connection. To be clear, I didn't remove the starter, as that is completely unnecessary, as you mentioned.
Yeah, it's pretty common way to remove fuel contamination. I even found a reference that it's the factory recommended procedure, though I didn't see the actual Ford document. I read where a lot of folks use Cascade dishwasher soap, but I went the Simple Green route. If you just use a little Simple Green you can probably get the smell out with water, but I used a lot (3g, then filled it up with distilled water), trying to get the fuel smell out of the plastic bottle. That ended up failing, and I just replaced the bottle.
Mark
Old Aug 28, 2010 | 02:13 PM
SpringerPop
Is "3g" three gallons of Simple Green?
That's a 3-to-8 solution, and kinda' "steep", doncha' think?
Heck, you could put what you drained out into spray bottles for re-use. That would solve the disposal problem.
Pop
Old Aug 28, 2010 | 02:17 PM
izzybird's Avatar
izzybird
[QUOTE=SpringerPop;9268203]
That'd take the stripes off a coon.
Old Aug 28, 2010 | 04:16 PM
ScaldedDog's Avatar
ScaldedDog
I'm new around these parts, but I promise I didn't just make this up...
Here's one of the places I looked: Diesel fuel in coolant system??? - Diesel Forum - TheDieselStop.com
Mark
Old Aug 28, 2010 | 04:39 PM
  #28
SpringerPop
..... wherein they recommended a 50/50 mix of Simple Green.
Whew! THAT will do some cleaning!
And yes, I still believe it's over-kill.
Pop
Old Aug 29, 2010 | 02:33 AM
  #29
Stewart_H's Avatar
Stewart_H
Mark, my apologies. I misread your post. I thought you were advocating removing the starter as the correct way to access the plug on the passenger side. I just went back and reread your post and I see where I misunderstood what you stated.
As for the sparks, that really shouldn't be a problem either because you should be well behind the terminals.
Stewart
Old Aug 29, 2010 | 09:27 AM
  #30
ScaldedDog's Avatar
ScaldedDog
Pop
In my case it probably was. Apparently you can use too little, though, as the shop that fixed the injector cup used Simple Green - of unknown quantity - and flushed it a couple of times, and it still had a fair amount of fuel in it. With 3g in there, I didn't have that problem.
Stewart
Also agreed. I had a swivel on the end of a 1/4" extension, and thought I could get it up between the starter and the block. That didn't work, of course, and was a really bad idea with the wrench handle pointed forward.
Mark
