Bronco II Ford Bronco II
84 Trans Trouble
Old Jul 14, 2008 | 09:59 PM
FULLQUIVER's Avatar
FULLQUIVER
84 Trans Trouble
Hi: New To The Bronco II World. I Just Bought An 84 BII 2.8 Auto (c-3, C-4?) 4 X 4. It's Seems The Tranny Runs Through The Gears Way To Fast At Low To Moderate Throttle. High Gear At 35 Mph. At Higher Speeds The Shifting Is Ok But At Slow Accelation The Motor Seems To Just Lug Through The Gears. The Vacuum Modulator Is Conected
(i Can't Tell If It's Working) But The Hoses Are Good. The Kick Down Linkage Seems To Be Adjusted Ok As The Higher Speed Shifting Is Ok.
Any Advice Will Be Greatly Appreciated
Thanks
Old Jul 15, 2008 | 01:23 AM
Canadianice's Avatar
Canadianice
I would check the fluid level first. Also check the condition of the fluid. It most likely could use a new filter and fluid change being that its a few years old. If that does not fix your problem try getting a new vacuum modulator.
Old Jul 15, 2008 | 02:36 PM
rebocardo's Avatar
rebocardo
I agree with the previous post in all that was said.
Having owned a 1985 with an automatic, I just want to say you might be experiencing normal operating behavior. The 2.8/automatic were dogs, the 2.9L/A4LDs were slightly better. Your transmission is most likely a C-5.
Old Jul 15, 2008 | 02:56 PM
Bear River's Avatar
Bear River
Former ******
My '94 Aerostar also lugs through the gears at low throttle, for me the engine has more than enough power to handle it anyway. A new modulator might help. You can get adjustable ones that might allow you to change the sensitivity somewhat.
Old Jul 22, 2008 | 07:42 PM
FULLQUIVER's Avatar
FULLQUIVER
Thank You For Your Input: The Quick Shifting At Low Speed Must Be Normal.
Is There Any Problem With Manualy Shifting The Gears At Low Speed?
Thanks
Old Jul 23, 2008 | 08:20 AM
TJDukit's Avatar
TJDukit
So long as you don't forget to shift when manually shifting an automatic and don't run the RPM's to high you should be fine.
Old Jul 23, 2008 | 09:29 AM
tbolt 460's Avatar
tbolt 460
the kick down rod hooked up
stuart olson
20
Apr 20, 2016 11:19 PM
fisher4life
Sep 25, 2014 12:52 PM
Jesser02EX
Jun 5, 2013 10:47 PM
97powerstroke
Sep 30, 2006 12:11 PM
georgiaford67
Dec 13, 2004 03:22 PM
