C6 transmission shutter
Old Dec 13, 2004 | 02:36 PM
georgiaford67's Avatar
georgiaford67
I just installed a used C6 in my 67 ford truck. When coming to a complete stop the transmission starts to shutter and seems to lock down. It shifts ok
when starting back up and goes through the gears pretty good. Could this be low fluild or the T/C? It is more evident once the transmission warms up.
After warm up it shifts hard into reverse and drive as well.
Any thoughts on this.
Thanks
Rich
Old Dec 13, 2004 | 03:07 PM
smoke n tires's Avatar
smoke n tires
sounds like a tc. could the engine be misfiring? or maybe have a bad mount? these are some other possibilities. im not sure if you just put a tranny in it or a complete swap. also double check your bolts are tight.
Old Dec 13, 2004 | 03:22 PM
georgiaford67
I basically done a swap on the transmission. The guy that done the swap for me said he put 9 qts
of fluid, but some say up to 12. The trans seems like it wants to gear down to 1st gear just before coming to a complete stop.
brickie
2009 - 2014 F150
Aug 11, 2013 08:30 AM
rockstate45
24
Jan 15, 2008 02:06 PM
john63
Mar 25, 2006 03:38 PM
93XR7
Oct 11, 2005 11:03 AM
ajasonk
Jul 29, 2005 07:47 PM
