Spout connection????
Old Jul 15, 2008 | 05:38 PM
danr1's Avatar
danr1
When you say its not quite right what do you mean? Not the same power, just not the same power you had before? Or Runs rough, hesitates/flat spot?
If the power seems down check the plugs, are they Motorcraft? or just cheap auto super mart type plugs?
You may be able to bump the timing a little more, a deg or two but be sure and check for any spark knock.
Old Jul 15, 2008 | 07:01 PM
Iantiler's Avatar
Iantiler
danr1, just not the same power as before. Plugs are not Motorcraft, plugs he replaced were Motorcraft copper. Engine has a Comp Cam, I don't remember the orginal timing..... I have it written down on the paper work that cam with the cam, see if I can find it.
Old Jul 15, 2008 | 08:01 PM
danr1's Avatar
danr1
The plugs alone could be the problem, little trial and error working on the timing setting should get you back to where it was.
That is once you put motorcraft plugs back in it.
Old Jul 15, 2008 | 09:03 PM
Iantiler's Avatar
Iantiler
dnar1, I'll change the plugs first and go from there.... thanks.
Old Jul 15, 2008 | 09:23 PM
danr1's Avatar
danr1
Your welcome, and if it doesn't work out and you need more ideas come on back.
Plenty of good people here to lend a hand.
Come back for a visit either way.
That and your posting the "fix" may just help others too.
x_man586
22
Sep 4, 2012 09:43 PM
Nally427
Aug 6, 2012 12:50 PM
rshiver
1983 - 2012 Ranger & B-Series
Dec 12, 2009 01:23 AM
javi2001
13
Jun 18, 2005 04:55 PM
Boldt
19
Jan 8, 2003 11:51 AM
