Sponsored by: Real Truck
mirror wiring help
Old Jul 14, 2008 | 08:21 PM
mstiles19's Avatar
mstiles19
mirror wiring help
what is the best way to wire the 2008 tow mirrors with heat and turn signal to my 2001? it seems like all of the different write ups that i have found on doing this are all a little different...
Old Jul 14, 2008 | 09:10 PM
jxdrl's Avatar
jxdrl
i soldered mine instead of cutting plugs. but i had all of the wires there. what do you need to know? wire locations?
Old Jul 16, 2008 | 01:18 PM
mstiles19's Avatar
mstiles19
i am looking to find out what each of the wires are for on the mirror and where i can find the correct wires to connect them to. My old mirrors had 3 wires running into them....can i just connect the same colors to each other?
Old Jul 17, 2008 | 12:55 AM
fivonut's Avatar
fivonut
found this link in the Superduty Tech folder sticky!!!
https://www.ford-trucks.com/forums/5...oday-pics.html
Here's another (this is what I used)
http://members.***.net/brian.osborn/...or%20wires.pdf
Also you'll need this to make them move correctly..
https://www.ford-trucks.com/forums/7...correctly.html
Old Nov 20, 2011 | 02:47 PM
FINKSTR's Avatar
FINKSTR
4wd High
Picture access
I'm trying to install the same mirrors on my '99 SuperDuty but for some reason am unable to access your pictures. Can you help me???
Old Mar 6, 2015 | 09:53 AM
Unrealo4's Avatar
Unrealo4
I bought a pair of DEDC 08+ mirrors off of amazon. I put them on my 03 Excursion. The wires were different colors on the off brand mirror. I was forced to troubleshoot which was which. I somhow got the mirrors to work correctly without having to dig into them and flip the wires on the servos. So I know its possible from the connector.
carl2591
Mar 4, 2017 10:07 PM
2WheelLee
Jan 19, 2017 10:15 AM
CTE2
Oct 5, 2015 04:23 AM
Suicidal
1997 - 2003 F150
Mar 27, 2008 05:53 AM
jrrfl
Nov 24, 2003 07:45 PM
