What do you think my 82 351 puts out?..........re-built, bore .30 over, performer intake, 4 barrel 600 CFM carb?. Just ball park, WHat did the 82 351 put out stock? I read 149hp........is this right?. sounds weak.
A truck engine is not about horsepower numbers, it's about torque numbers. It takes torque to get a heavy load moving. As an example, put a higher revving mustang engine in it that has higher horsepower numbers, and you will be disappointed in it's performance using it as a truck.
I read that the 82 351we put out 180hp @ 3600 rpm and 285 ft lbs torque @ 2400. You should have at least 200 hp now . A good cam, head work or heads, higher CR and headers could double that. A 302 made 130hp in 82, so I'm sure the 50 extra cubes made more than 15hp.
4 barrel or 2bbl originally? If it was originally a 4bbl, I doubt you gained more than 5hp. If 2bbl, 20hp could be possible.
Big gains won't come unless you at minimum change the camshaft/exhaust and probably increase airflow through the heads. What you want to stay away from in a truck is a 'peaky' engine, so stay away from narrow lobe separation and lots of overlap as they will tend to make power at higher rpm in a narrower range (there are exceptions, though, you can do one or the other and still probably have decent low end grunt).
For compression increases, expect 10% gain for 8:1 to 9:1, 15% gain for 8:1 to 10:1, 18% for 8:1 to 11:1, etc. The higher in compression you go, the less you gain, so I honestly wouldn't go much over 9:1 compression as it'll just cost you more at the pump without much more power.
What are your plans for the truck? If you want a mud bogger or stop light to stop light racer, it'll be vastly different than a tower/hauler or rock crawler type vehicle.
If you still have the stock cam you didn't gain much, install something like the 351HO cam(or any aftermarket RV cam), a decent exhaust with anything but the stock manifolds and that motor should produce about 250hp... and 350 ft lbs TQ.
That's not totally true...
I have a 345whp "mustang" engine going in mine. While i do expect it to be less spirited than the mustang was, I doubt I'll be disappointed. The engine made mad torque as well. And I can always gear it to help out.
