A/C clutch doesn't cycle off
Old Jul 13, 2001 | 01:04 PM
steveski's Avatar
steveski
The A/C compressor clutch on my '84 F150 (5.8L) does not cycle (turn off) ever since the system was recharged. A/C is a R134a retro and blows like the arctic, but it used to cycle approx every 8 secs prior to recharging. does this indicate a possible problem? Thanks in advance.
Old Jul 16, 2001 | 03:39 PM
aerocolorado's Avatar
aerocolorado
This is good! It was cycling way too frequently before, probably due to low charge. Ford systems often do not cycle at all if ambient temperatures are around 80 degrees F or higher. Below that, they usually they cycle roughly 3-4 times/minute but this is dependent again on ambient temperatures, condenser efficiency, and where you are checking cycle rates (in town driving vs highway). I converted a '91 to 134a and it cycles on the highway right on with the charts, however in slower city driving it rarely cycles. Take an old 12V bulb and hook the leads between the cycle switch and run it inside the cab where you can watch and time the cycles.
Old Jul 16, 2001 | 04:32 PM
billyb's Avatar
billyb
my 88 also cycles like yours since the conversion. i have been using it for a year and a half with no issues and good cold air.
Old Jul 18, 2001 | 01:26 AM
chillyman's Avatar
chillyman
jbtecnico1
Escape & Escape Hybrid
May 14, 2015 12:19 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jun 8, 2014 09:06 AM
jefftb
Aug 11, 2013 07:02 AM
paradiddle
Jun 13, 2003 02:22 AM
