3.0 noise
Old Jul 13, 2008 | 11:17 AM
darascal's Avatar
darascal
3.0 noise
my problem is the noise I get when the engine is at higher RPM like right before it is about to shift. the noise only seems to occur when the the truck is in drive and moving. It sounds kinda like vavle noise to me but its hard to tell for sure when it only happens when it is moving...it is a tapping rattling kind of sound.3.0,180000,auto any help or ideas?
Old Jul 13, 2008 | 01:19 PM
darascal's Avatar
darascal
how hard is it to adjust the valves in this engine??
Old Jul 13, 2008 | 01:39 PM
Dad's Truck's Avatar
Dad's Truck
Is it always, or just when it's cold or been parked a while? Mine does it too, but with a 2.5. I think I've got mine narrowed down to a throwout bearing or something in the trans, because it sounds like it comes from lower and further behind than the valvetrain.
Old Jul 13, 2008 | 01:43 PM
darascal's Avatar
darascal
actually it happens most after the engine has warmed up...which is why I thought it might be the oil so I brought it to the dealer and had the oil changed
Old Jul 16, 2008 | 05:55 PM
darascal's Avatar
darascal
I have never had a transmission "rattle". Is this normal? Oil change seems to have made no improvement.. would valve train noise come and go or would it be more constant?? any ideas?
Old Jul 16, 2008 | 08:39 PM
Dad's Truck
Have the trans lube checked if you haven't already. Might be low. Or dirty. Or both. I know mine makes noise when it's due for a change because it's full of dirt and whatnot from wear.
Old Jul 19, 2008 | 05:53 PM
darascal's Avatar
darascal
Well I found the problem..I think... it seems the camshaft synchronizer is the culprit,I pulled the CPS and found it was dry inside the whole thing so a couple of squirts of WD and the noise went away
Old Jul 20, 2008 | 10:46 AM
tomw's Avatar
tomw
WD is NOT going to fix that problem. It is more of a solvent than a lubricant. I predict you will hear it again soon. The synchronizer most likely needs to be replaced.
tom
Old Jul 21, 2008 | 07:57 PM
darascal's Avatar
darascal
I agree that I haven't fixed it but at LEAST I was able to figure it out
Old Jul 21, 2008 | 08:47 PM
Rockledge's Avatar
Rockledge
I would have guessed that what you were hearing was detonation (a/k/a "pinging").
In any case, nice find. I agree with Tom, you should change out the cam synchronizer assembly ASAP if it is making noise. It is important to note that 1996+ 3.0L vulcan engines have a gear on the camshaft synchronizer shaft which interfaces with - and spins- the oil pump drive shaft. Which means that when the cam synchro shaft fails and stops spinning, the oil pump drive shaft also stops spinning, and the pump stops pumping. In such case you can pretty much say goodbye to that motor.
swilson
May 8, 2009 05:21 PM
Craig510
Modular V10 (6.8l)
Jul 4, 2005 11:17 PM
captaincanuck
Jun 7, 2005 07:34 PM
jakeomni
May 11, 2005 10:38 AM
