'97 E-350 CW Intermittent Noise
Old Jul 12, 2008 | 12:27 PM
DaviMac424's Avatar
DaviMac424
I have a '97 E-350 5.4L with 162k, and am having issues with an intermittent noise coming from the engine. The noise typically happens while the van is idling in drive, but not moving. It is a high pitched squeak that originates under the hood but can be heard through the exhaust as it shakes on its hangers. When the noise occurs, it brings the RPM's down by what I would guess 3-400 (no tach). It last for 1-2 seconds before going away, with the engine coming back up to a normal idle. I initially thought it was A/C related, but it happens with the A/C on and off. The van threw a belt a month or so ago, and it has been replaced. All of the pulleys looked okay when I changed the belt. I'm almost certain it has to be one of the accessories driven by the belt, as it sounds like a belt squeak and brings the revs down. Any suggestions?
Thanks,
David
Old Jul 12, 2008 | 06:24 PM
dan001978's Avatar
dan001978
Hi David,
It sounds like your belt is slipping. This would explain the rpm drop, and the noise you described is consistent with this. Why it only occurs at idle when your driving could be a number of reasons, less tension on the belt(?) etc.
I would start by getting a can of belt dressing from any autoparts store, truck stops usually have it too. It will condition your belt and may eliminate the problem. Belt dressing also has a tendancy to cause squeaking when you first apply it but it will go away. I would start with that and if it doesn't work look into adjusting the tension on your belt tensioner, not sure how this is done but maybe someone else has done this before. If you just had the belt replaced maybe you could take it back to the shop where you had it done and ask them to maybe tighten the tension arm for you?
Good luck, let me know how you make out.
Dan
Old Jul 12, 2008 | 06:33 PM
DaviMac424's Avatar
DaviMac424
Dan,
Thanks for the suggestions. I changed the belt myself, as I do all of my own work (except transmissions ). The automatic tensioner felt perfectly fine to me. Why do you think that the belt slipping would cause the RPM drop?
Thanks,
David
Old Apr 5, 2010 | 11:47 PM
Fox Fader's Avatar
Fox Fader
You don't put belt dressing on a serpentine belt. It's made for the old V-belts.
Old Apr 6, 2010 | 08:33 AM
gearloose1's Avatar
gearloose1
Check for excessive loads on the belt..
laney5
Dec 12, 2014 09:18 PM
raptor2005
Nov 2, 2010 07:11 PM
davelength
May 23, 2010 12:54 PM
bpd357
1997 - 2003 F150
Mar 21, 2008 11:14 AM
