Posi trac?
Old Jul 11, 2008 | 08:34 PM
drof46's Avatar
drof46
Posi trac?
I am thinking of adding some horses to my 1979 ford. How do I tell the difference in a 28 or 31 spline rearend? I plan on going from limited slip to posi and don't want to buy the wrong setup.
While I'm at it, is there a cheaper way to go posi, other than ebay?
thanks,
Old Jul 11, 2008 | 08:44 PM
Tha_Stepside's Avatar
Tha_Stepside
First of all, chevy did posi-trac, and ford/dodge did LSD, both are the same thing just to clarify what we are talking about. If you have a 2wd more than likely you have a 28 spline, 4wd will be 31 spline. If you are still unsure the best way to tell is to take out the axleshafts and count the splines, not any harder than changing the oil in the good ol' 9". There is no real cheap way to get an LSD rear end other than buy a good used one for cheap or getting one for free. The best LSD rearends are the Detroit True-trac and they run about $450, the best place i found to buy one from are completeoffroad.com they are incredibly knowledgable of their products and are very good to deal with with excellent service, I would highly recommend them.
Old Jul 11, 2008 | 08:51 PM
Dr. Dirt's Avatar
Dr. Dirt
if you have a limited slip right now then that is what Ford's posi trac setup is.
Old Jul 11, 2008 | 10:55 PM
BrentNewland's Avatar
BrentNewland
Last months argument about the topic: https://www.ford-trucks.com/forums/7...highlight=posi
Old Jul 11, 2008 | 11:25 PM
85e150's Avatar
85e150
I actually tried to look up all the names for LSD's a while back and did a "know-it-all" post on it on yet another arguement thread. GM's "Positraction" became a default or generic term, just as Kleenex etc. However, in looking these up, I found that there are several different designs of the limited slip. Clutchs/springs, cone/springs, ramps/springs, maybe a couple others. Then there is how effective they are. Fords from a ways back were termed weak, not sure if the current ones are better.
Anyway, pretty pics of several flavors here on this site, so you'll know what to look for ifn's you dasn't already...
Currie Enterprises Racing Rear End Categories
Old Jul 12, 2008 | 12:08 AM
hp246's Avatar
hp246
I believe the 31 spline was used on 2 wd starting sometime during 1976. My 76 had 31 spline. Numberdummy passed this tip along to me, and it checked out. Most (not all) 31 splines have to round holes in the end of the axle. Maybee ND can chime in here.
Old Jul 12, 2008 | 08:48 AM
drof46's Avatar
drof46
Thanks for the civil responses. Read that previous post listed above and I would have been slightly pi**ed to get that kind of response. Thankfully I am not in high school. I will be spending some money on this project. It won't be fast enough for the race track but she will be fun as hell to drive.
later
Old Jul 12, 2008 | 07:01 PM
4x4 Bart's Avatar
4x4 Bart
I like Powertrax lockers for their ease of installation. They make two kinds, hard or soft lockup. The advantage is you don't have to remove and reset the ring and pinion. I believe this is true for all applications. Check out their web site.
Old Jul 12, 2008 | 08:16 PM
mark a.'s Avatar
mark a.
Detroit True trac, now there is a real piece of crap. I had one once it didn't even make it one mile before it let loose. They did give me my money back though. I didn't want another one after that.
Old Jul 12, 2008 | 11:12 PM
Tha_Stepside
Maybe you got one of the few malfunctioning ones, I have installed over 20 of these in all brands of trucks and all have worked perfectly. Detroit/Eaton is the #1 in diffs, they have been making diffs for a long *** time for damn near everything from logging/highway trucks to quads, they know what they are doing better than anyone else out there. What caused the failure if you dont mind me asking?
