alumaloy
Old Jul 11, 2008 | 06:47 AM
Motorhead351's Avatar
Motorhead351
alumaloy
does it really work?
I did an internet search, seems individual experiences were mixed.
Thinking more about my dual TB idea, would require my hacking the TB side of the intake completely off.
Figured I could align the new plate/tb's with pins, then use the alumaloy to make it permanent. I know nothing about joining two metal pieces...I can mig weld a little but thats where it ends, is there another alternative? The idea of being able to use a propane torch is attractive, and perty much what Im limited too...although I might be able to find someoe willing to work with me, that has an acetalyne torch, Im not counting on it though.
Old Jul 11, 2008 | 06:53 PM
stractor's Avatar
stractor
Its not as easy as it looks-Alumaloy is more of a solder and soldering than anything else. I suppose that if you had a good deal of experience in welding you could do it, but aluminum is very trickey to weld. Have some one tig weld it for you.
Old Jul 12, 2008 | 05:27 AM
Motorhead351
Welding is out of the question, so far the quotes have been beyond ridiculous.
I have some scrap aluminum and the alumaloy is on the way...Im not very optomisitc...
Old Jul 13, 2008 | 03:49 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Mill the pieces, drill and tap srew/bolt holes, cut a gasket, and locktite everything?
Old Jul 14, 2008 | 05:05 AM
Motorhead351
Dont think there would be enough material on the outter edges to drill and tap, I thought about that, matter of fact it was part of my least expensive plan, which was to have tabs welded at key points, then do as you described.
rbatten
2004 - 2008 F150
Mar 5, 2011 12:56 PM
tcook95
13
Jan 31, 2008 06:44 PM
doc27292
Oct 5, 2003 08:10 AM
doc27292
Sep 26, 2003 09:05 PM
optikal illushun
Sep 17, 2002 02:19 PM
