Sponsored by: Real Truck
Front End Banging While Turning
Old Jul 31, 2008 | 09:47 PM
Mercury45's Avatar
Mercury45
thanks for the info DC, think the older trucks need them like ours? 99 - 04?
Im on 6" lift with 37" tires, I should have done these when i did my ball joints... hah
but i would not mind blowing a few hours if it tightens up my truck
kenny
Old Jul 31, 2008 | 09:57 PM
DCSpecial's Avatar
DCSpecial
On the 05-08s with the radius arms and coils you change caster when you add the leveling kit w/o lowering the radius arm mount (caster is the angle of the upper ball joint over the lower ball joint...positive means it's tilted towards the door, negative means it's tilted forward to the bumper).
You can adjust for that caster change with the cams in the leveling kits.
For taller lifts you need radius arm drops, redesigned radius arms or 4-links to get caster back to an acceptable setting.
IMO, you definitely don't want to go more negative on caster than stock on the 05-08s...often times you want a more positive caster than the factory on the lifted trucks to improve the handling.
On the leaf springs 99-04 trucks the caster isn't as effected as much since the caster generally doesn't change when doing a leaf spring or hanger and shackle (it will change some doing just a shackle on it w/o the hanger). W/O knowing what your caster setting is, it's hard to say if you need them or not on a 99-04.
I still run the stock upper ball joint cams on my 01 with 8.5" and 38s.
If you want to read about caster, camber and toe and alignments, here is a link that has some good info:
Wheel Alignment A Short Course
Old Jul 31, 2008 | 11:01 PM
LaxPlaya21's Avatar
LaxPlaya21
There is a bracket that came with the procomp leveling kit that lowers where the track bar connects... I think haha. You see the bolt where the track bar meets at the bracket, that is not stock. Look at the picture.
And I believe the bushing were the caster cams. i will take pics tom when its light out.
[/QUOTE]
Monster-4
Feb 12, 2016 12:31 AM
TexinCali
Oct 4, 2012 01:50 PM
TNT in Round Rock
Feb 4, 2012 01:19 PM
Bowie
Apr 12, 2011 12:17 PM
schwarz020879
Oct 18, 2009 06:07 PM
