Steering Box Location?
Old Jul 10, 2008 | 09:40 AM
Ex1900Driver's Avatar
Ex1900Driver
Hi...
Well I have done the research and it appears I may have to adjust the steering box on my 2000 Excursion.
I have the simple directions on how to do it... but to ask a silly question,
Where is the steering box so I can actually try fixing my steering which is loose to say the least.
Thanks
GDC
Old Jul 10, 2008 | 10:04 AM
Ford554's Avatar
Ford554
Front lower driverside of the engine compartment. Just follow the steering shaft down from the firewall. There should be a little black plastic guard covering the top of it...you can't miss it.
Old Jul 10, 2008 | 11:56 AM
APEXDUCK's Avatar
APEXDUCK
Easiest to access after you remove the air filter box from a gas X. Remove the filter and pull the engine side of the filter box back toward the fire wall (bungy around it and hooked to the hood lifter works great). look right down and you will see the steering box down below. Nut with a allen head screw on top. Mark the position of the allen screw with a grease pencil or white crayon first. loosen the nut a little to allow you to turn the allen head screw clockwise no more then 90 deg (1/4 turn) use a open end wench to tighten the nut while holding the allen head screw in place. 10 minutes tops to complete this. I'm not sure what's in the way of you have a smoker engine.
APEXDUCK
Old Jul 10, 2008 | 12:14 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
Here's a picture.
The pink striped bolts are on the four corners of the steering box in this picture.
The center bolt with jamb nut is the one you will be mucking with.
The second one is out of focus but you can see what you need to.
I am leaning up against the drivers side fender so the firewall is to your right in these pictures.
I have a V10...
Good luck,
joe.
Old Jul 11, 2008 | 10:31 PM
Ex1900Driver
Thanks for the help everyone.
GDC
ashlynsalvo
2009 - 2014 F150
Jun 26, 2017 12:31 PM
invstr55
Sep 24, 2016 10:37 AM
BigBlueCat
Jun 7, 2016 06:34 PM
jamhh
Apr 26, 2013 09:33 PM
Diesel 724
21
Jul 8, 2011 05:01 PM
