tranny leak
Old Jul 9, 2008 | 10:52 PM
2classics's Avatar
2classics
tranny leak
my trans leaks out of the bell housing. 78 c6 f250. What could it be, what does it mean? Started small and is gettng worse. Sorry, don't know much(at all) about autos.
Old Jul 9, 2008 | 11:14 PM
85e150's Avatar
85e150
Trans oil or engine oil?
Trans oil: the torque converter, the TC seal or other seal is going.
Engine oil: rear main seal.
If you're lucky: Engine oil leak from back of intake manifold leaking through the bell, looking like trans/rear main leak.
If you're not luck, it's pull the trans time.
Old Jul 10, 2008 | 07:40 AM
2classics's Avatar
2classics
It's Red. Is it time for a rebuild or changing seals pretty easy?
Could use this as an excuse to build a good c6
Old Jul 10, 2008 | 07:39 PM
85e150's Avatar
85e150
Plan to pull it out. Since you are into it for that labor and the teardown/reseal labor, adding shift kit and other beef up parts is small change on top of what you are spending. So: make it the way you want it.
fordinmudd
Nov 11, 2023 11:43 AM
Paul h
Jan 16, 2017 07:36 PM
BroncoRN
May 6, 2016 02:20 PM
chrison600
16
Nov 8, 2014 08:42 AM
pilgrimbizket
Nov 16, 2013 02:05 PM
