trans computer install
Old Jul 9, 2008 | 04:40 PM
crazymike's Avatar
crazymike
i finnaly found a trans comp to put in my truck,got a good price too 72.60$ came with a warrantee and everything. and since its 90 outside i think i'll wait for a little while to put it in. whats the best way to pull out the old one and put in the new one? and i going to be able to do it from behind the computer from inside the cab or is it all at the front under the plastic cover?
Old Jul 11, 2008 | 01:37 AM
ford trans tech's Avatar
ford trans tech
if its a 91 model
you have to remove and install from under the hood
first remove the connector bolt 10mm head
then remove the two retainer flange nuts 7/16 heads
remove the retainer
then remove a couple of the screws from the plastic inner fender panel around teh area of the processor use a long screwdriver and a rag between the fender and the inner fender and gently pry down the plastic inner fender to allow enough room to remove and replace the processor
Old Jul 11, 2008 | 12:04 PM
David85's Avatar
David85
With a price like that its really hard to justify the cost of an aftermarket computer. Hope it works for you, good luck.
garm59
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 16, 2014 11:36 PM
l BlAcK l
23
May 4, 2011 07:04 PM
nofortunateson
1983 - 2012 Ranger & B-Series
19
Dec 31, 2007 12:13 PM
DESERTRED4
1966 - 1977 Early Broncos
Dec 16, 2007 11:02 AM
dptywrdn
Bronco II
Jan 12, 2001 06:31 AM
