Offroad & 4x4
fuel issues
Old Jul 9, 2008 | 09:09 PM
captain p4's Avatar
captain p4
Originally Posted by STGFordCrazy04
probably vapor locking.
When it gets hot is it hard to crank and have no power past 2-3000 rpm? Let it cool 10-15min and it cranks right up?
Mine does this, but I thought it was heat soak on the starter from the headers. whats vapor locking?
Old Jul 9, 2008 | 09:17 PM
kjett's Avatar
kjett
Paul, vapor lock is just that, the fuel in the line and in the bowl gets so hot that starts to turn to vapor, and essentially locks the motor up as it won't allow the fuel bowls to open to let more fuel in, causing the motor to be fuel starved. When it gets like that, try to pour a little fuel in the carb and see if it cranks over then. If it fires up and then dies, then you are vapor locked.
Old Jul 9, 2008 | 09:24 PM
captain p4's Avatar
captain p4
I'll have to try that next time it happens. What would cause the fuel to get that hot?
Old Jul 9, 2008 | 09:32 PM
kjett's Avatar
kjett
Routing of the fuel lines may be too close the the exhaust manifold.
Old Jul 9, 2008 | 10:39 PM
2classics's Avatar
2classics
century has good stuff. I'll have to read that when i'm sober.
Old Jul 11, 2008 | 08:23 PM
2classics's Avatar
2classics
UPDATE:
not the fuel lines being plugged. I replaced everything from the tank to the pump and blew out everything else with air. Next is the fuel pump.
Old Jul 26, 2008 | 12:30 AM
2classics's Avatar
2classics
not the fuel pump. Not the the needle and seat. The only thing left is crap pluging the pick up in the fuel tank. Everything else is new(besides powervalve). I hate throwing parts at things. I was for sure it was the fuel pump. I'll keep you posted.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
