White smoke :(
Old Jul 9, 2008 | 07:55 PM
zx250's Avatar
zx250
Of the next Riffraff East
What did the exhaust side of the turbo look like when you had it out? Dry?
Old Jul 9, 2008 | 08:40 PM
solareclpse2000's Avatar
solareclpse2000
i know it may sound weird but check your CCV and make sure its routed correctly and its not clogged.i have seen that come up a few times on this site.
Old Jul 9, 2008 | 08:47 PM
unluckylow's Avatar
unluckylow
My CCV no longer vents into the intake, I ran it down and it now vents underneath the truck. I no its not cloged because when the engine is smoking bad the white smoke is also coming out of the CCV line.
Old Jul 10, 2008 | 12:06 AM
4inchlovin's Avatar
4inchlovin
Originally Posted by deereman4020
i still think you have a groove scratched on one of your cylender walls that might create the burnt oil smell and the oil level down to the add level hope it isnt that problem
I have to agree... Unfortunately what you have explained so far is exactly how my truck started to go down hill... You said earlier that you had a cold air kit and unless its AFE i just don't trust reusable filters on these trucks... Now as you can see in my sig. shes getting a new motor...
Your next best bet is a compression test... That will tell you if you have a bad cylinder... Good luck!
Old Jul 10, 2008 | 05:52 PM
unluckylow's Avatar
unluckylow
I think a compression test was done and I believe all cylinders checked out good. I do have a contact at ford that will help me with a injector buzz test.
Old Jul 10, 2008 | 05:55 PM
zx250's Avatar
zx250
Did I understand you earlier when you said you had just rebuilt your turbo?
Old Jul 10, 2008 | 06:44 PM
unluckylow's Avatar
unluckylow
Yes the turbo was removed and all of the internal seals and gaskets were replaced.
Old Jul 10, 2008 | 06:58 PM
zx250's Avatar
zx250
It could be that is still were your problem is if a seal didn't work right. Do you have any oil on or around the turbo housing?
Old Jul 11, 2008 | 12:59 PM
unluckylow's Avatar
unluckylow
I dont see any oil around the base of the turbo where it bolts to the turbo pedistial, but I do see oil (in the valley) on top of the intake manifold, but I think that is from when the turbo was pulled or the when the injector were pulled. I will verify this today.
Old Jul 13, 2008 | 08:02 PM
unluckylow's Avatar
unluckylow
Well the smoke stopped and I am relieved. I did discover I do have some blow by comming from the CCV but as far as white smoke comming from the exhaust pipe no more. one day I will probabley have to replace the rings but as far as now the truck is running good.
Old Jul 13, 2008 | 08:03 PM
unluckylow's Avatar
unluckylow
Thanks guys for all of your help
Old Jul 13, 2008 | 09:10 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Just to clarify, there should always be a mist of oil vapor coming out of that hose. As long as you take the oil fill cap off, and the mist is a constant stream, thats GOOD. When you go getting a puff puff puff pulsing action, thats BAD.
Old Jul 14, 2008 | 12:24 AM
  #28
4inchlovin's Avatar
4inchlovin
Mine looked like a steam engine on my old motor!!! lol
Old Jul 15, 2008 | 06:06 PM
  #29
unluckylow's Avatar
unluckylow
With the oil cap on you are saying there is suspose to be some smoke and comming out of the vent on top of the driver side valve cover. I just want to clarify or is it when i remove the oil cap that it is suspose to smoke.
Old Jul 15, 2008 | 06:29 PM
  #30
4inchlovin's Avatar
4inchlovin
No smoke out the CCV is normal... Out of the valve cover cap is bad....
