Oil pan clearance? 94 4wd 4.9
Hi, I bought a 94 4wd 6cyl with 188k on it and think I may have to replace the oil pump and main and rod bearings. It's starting to rattle a little when you first start it up in the morning, and the oil pressure falls to nothing when idling warm. My question, is there enough clearance to remove the oil pan and replace the bearings without pulling the motor? If so, can the rear main bearing be replaced also? there's no leaks so I shouldn't have to replace the rear seal unless I just have to. thanks in advance
Thanks for the info, I did a search, and from what I read , I can replace the bearings except the rear main without pulling the engine
sickpup2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
06-25-2020 04:35 AM
maxtor
04-16-2009 01:33 PM
