Oil pan clearance? 94 4wd 4.9
Old 07-07-2008, 02:22 PM
lestro's Avatar
lestro
lestro is offline
Hi, I bought a 94 4wd 6cyl with 188k on it and think I may have to replace the oil pump and main and rod bearings. It's starting to rattle a little when you first start it up in the morning, and the oil pressure falls to nothing when idling warm. My question, is there enough clearance to remove the oil pan and replace the bearings without pulling the motor? If so, can the rear main bearing be replaced also? there's no leaks so I shouldn't have to replace the rear seal unless I just have to. thanks in advance
Old 07-07-2008, 03:18 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
you have to remove motor mount bolts, fan shroud and jack up the motor.
do an advanced search for oil pan removal for many posts on this subject.
Old 07-07-2008, 04:55 PM
lestro's Avatar
lestro
lestro is offline
Thanks for the info, I did a search, and from what I read , I can replace the bearings except the rear main without pulling the engine
96_4wdr
Aerostar
20
01-15-2024 12:06 AM
sickpup2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
06-25-2020 04:35 AM
'78F250351m
03-14-2011 04:15 PM
maxtor
04-16-2009 01:33 PM
tcd5834
Modular V8 (4.6L, 5.4L)
07-09-2005 10:52 AM
Quick Reply: Oil pan clearance? 94 4wd 4.9
