exhaust question for 1982
Old Jul 7, 2008 | 11:10 AM
thomaspeters's Avatar
thomaspeters
I have not owned my 1982 f-250 from brand new it currently does not have a catalytic converter installed was there from factory? Sorry about the spelling The truck has 351 and is 4 wheel drive. My inspection mechanic says there was one from factory in it?
Old Jul 7, 2008 | 03:52 PM
Bear River's Avatar
Bear River
Former ******
Even if there was, the vehicle is manufacturer prior to 1983, which should make it exempt from requiring one unless it won't pass without one. If it passes the sniffer, you should be good, though local laws may be more stringent than federal law in your case.
Old Jul 11, 2008 | 10:08 AM
Sycostang67's Avatar
Sycostang67
It will depend on the GVWR of the truck. If it was 8500lbs or greater, it wasn't required to have a cat, but it would probably have 2 smog pumps. There should also be a sticker on your radiator support that says "NON-CATALYST" or "CATALYST".
Old Jul 11, 2008 | 10:14 AM
Bear River's Avatar
Bear River
Former ******
My guess is that since it is an F-250, that it did not come with a cat. So long as the other smog equipment is working, and the vehicle can pass an emissions test, you should be good. And Sycostang is right, thee is a sticker either on the radiator support or somewhere under the hood that should state whether or not the vehicle requires a cat.
Old Aug 1, 2008 | 06:57 PM
green 1969 f100's Avatar
green 1969 f100
Thumbs up
I drove a 1985 F250 service truck purchased new as a non catalyst with a 351 engine.
Rusty_S
Jul 7, 2014 10:28 PM
Fordzilla80
WTB - Parts & other
Mar 28, 2013 01:30 PM
mbailey94
Sep 13, 2012 03:12 PM
mitchy
Jan 29, 2008 05:43 AM
1982fordf100
Nov 30, 2003 10:37 AM
